#2281
Be glad you have it. The car drives like a FWD car with the US style. Especially as the trans ages and the rear torque goes down
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
#2282
Washed it, waxed it with Meguiar's carnuba wax, buffed it with a lambs wool power buffer and put it on eBay.
See it under Race Cars (not street legal)/ Road Racing. Buy it.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#2283
Got the 6 speed in, been driving and checking it. so far had to adjust a couple things but over all very very impressed with it.
#2285
new rear struts in the gl, both the old ones were completely blown.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
#2286
Repaired/upgraded the Alternator wires, hopefully no more intermittent christmas tree lights and stalling
current stable, subject to change without notice: ![]() 1995 Red SVX, 4.44 & Quick Change 2014 Nissan Titan S 4X4 1992 Teal SVX parts car |
#2287
Saturday: Took a wire wheel to the parts that came out of my electrolysis bath, washed them, and then got the paint out. Before/after comparison:
![]() Sunday: Dropped my fuel tank to I can tackle the totally ****ed up lines back there. That droopy thing is a brake line that some halfwit mangled into place (didn't even bother removing the old blown ones, the spots where they touched were causing the newer ones to corrode badly). The rust spots on the chassis are going to get cleaned up and painted with POR-15. Should be good after that. ![]()
#2288
I had overfilled the 5EAT in the Outback.... by a quart. Drained it out and it APPEARS that the cold start issues I had are gone.... I've driven it only once since and the ambient was 7 C... so not really cold.
The problem was, it went into "uphill maps" and was very reluctant to shift up for the first mile (after the first steep hill). Also, the shift from 2nd to 3rd was harsh. Anyone with similar experiences? /T |
#2289
Had a 4 wheel alignment job done today - the toe was out quite a bit, both sides - one minus, one plus.... all others were suprisigly close to spec considering I have replaced all joints....
Tracks real straight and true now - a huge difference ! /T |
#2290
That looks brand new!
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
#2291
Thanks! I ordered some POR-15 for the rear subframe, so it should look ultra-pretty when completed and be immune to rust forever. I'm also going to get my hands on some 3M urethane to fill in and stiffen the bushings. They're all in fairly good shape so I don't want to go through the work of digging the old ones out.
#2292
#2293
Created a very loud exhaust leak
http://i840.photobucket.com/albums/z...93705d9zzz.png |
#2294
Don't know if this qualifies as having done something for my SVX or not.. Bought a "donor" car a couple of weeks ago. Unfortunately not salvageable, but my SVX now has her own supply of spare parts that should get her five to ten years more.
I'm going to endeavor to send as little to the crusher as possible, I'm going to preserve, bag and tag everything that I can that I would foreseably use. The rest I'll post up for sale when I can. I'd rather that, than just see it slowly disintegrate. I can't tie up a spot at my mechanic's shop forever, but I won't throw away the irreplaceable either. |
#2295
Ummm, bought a few more over the past few weeks. Including PhastSVX's former turbo SVX which will slowly be getting a complete overhaul to bring her up to speed over the next calendar year from now.
