Still having running issues
UPDATED LIST:
EVERY hose, valve and solenoid under the intake including the iris valve intake gaskets pcv valve fuel filter Throttle Body and IACV cleaned and new gaskets 6 reman injectors New hoses on top of fuel tank behind back seat New oem fuel cap door 4ga alternator wiring upgrade Brand new intake boot NGK Laser Iridium Plugs Coil Packs (low mile used, so still could be culprit) Coolant Temp Sensor Knock Sensors MAF (twice, used so still could be culprit) TPS and adjustment (several different ones, used so still could be culprit) Cam and Crank Sensors (several different ones, used so still could be culprit) Subaru SVX Stage 1Av1 ecu and tcu from ecutune.com It is hard starting NOW... never had that issue until taken to mastro subaru for all valves and solenoids under intake. It has a hesitation under normal acceleration. Random stumble meaning it feels like the car SHUTS OFF for a 100th of a second or so... VERY QUICK AND VERY RANDOM The idle isnt rough but it isnt right... hard to explain... the bobblehead on my dash and the vibration when on the brake pedal is worse than ever... BUT VERY MINOR. Any suggestions?????? Signed BROKE AND STILL BROKEN P.S. I calculated my gas cost to drive it to svxfiles... good lord... 971 miles... BUT I AM RUNNING OUT OF OPTIONS... NO TURNING BACK NOW!!! |
Re: Still having running issues
Maybe it would make sense to meet up with one of the Florida guys and test swap some of the easy things with know good ones. I'm thinking mostly of Maf and coils.
MAF you have replaced twice? I have a stock maf here that I know works well, I plan to drive down, though not in the svx unfortunately, to the tampa meet feb 15. I could grab the maf if you want to try another.
The items you are listing seem like vac hose not correct perhaps? or just loose |
Yeah... I am down to try it... is it for sale?
Or try only? |
That depends if it works for you.
I do not think I need it so if it works it is. |
I would check them.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
