Old 12-14-2013, 03:13 PM
major7venth's Avatar
major7venth major7venth is offline
M7
Fix the click click
Install a relay as shown in pix.
simply connect the relay as follows.
#30 High power 12V from the battery + terminal (must be fused)
#85 Battery ground negative terminal
#86 trigger wire (from the factory starter (solenoid wire)
#87a to the starter solenoid.
and that's it. Works good no more click.
More details.
Disconnect the factory starter solenoid wire and cut of the factory female slide connector, strip the wire and crimp on a new female connector. Use a male slide connector and wire to the relay, (If one ever wants to go back to the factory wiring, just plug it back into the solenoid). Make sure you have at least 14g wire and 12g from the battery and from the relay to the starter solenoid and are making really good connector crimps.
Old 01-13-2014, 12:46 PM
Hondasucks's Avatar
Subaru Technician
Re: Fix the click click
One thing I would do differently on that is use the waterproof connectors that have the rubber over the end, or at the very least use dielectric grease on it. You can get weatherproof plugs that have that relay connector on them, since it is a standard connector. I'm going to do this to mine soon, when I do I'll see how hard it'd be to make a plug-in harness that I can make available to the forum as a kit that you'd just plug in to power and the starter.
1986 VW Jetta
Old 01-20-2014, 01:51 PM
Sign me up for one. Relay included?
Old 01-20-2014, 03:46 PM
gwynethh's Avatar
gwynethh gwynethh is offline
What about this one?
http://www.ebay.com/itm/Waterproof-R...-/110844258626
Waterproof Relay Assembly - 40 Amp 12v Sealed Relay Assembly With 12" Leads
or this one
http://www.ebay.com/itm/Waterproof-R...item19d8b76d7a
Waterproof Relay Kit - 40Amp 12v Sealed Relay, Socket, Terminals & Mounting Tab (no leads)
Old 01-21-2014, 02:56 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Something like this?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
