#2116
Took the horns off my '92 LS-L parts car and installed them on my '94 Dodge Dakota pickup which had a dead horn! Now the Dakota honks like an SVX!
#2117
To answer your question as to what I have done to my SVX today.
1. I drove it to the petrol station and filled it with fuel (gasoline for the Americans). 2. I drove it to work (a gig - I can fit my drum kit inside it.) 3. I drove it home and locked it in my garage (car hole) Oh! I almost forgot. I manually wound up the seat belts and pondered on the many rattles the interior has developed.
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com Last edited by BRADY; 11-01-2013 at 09:40 AM. Reason: Grammatical and syntax. |
#2118
Finally hit 160,000 yesterday, I'm doing a bit less than 5,000 miles per year.
#2119
Ran a full bottle of seafoam through the throttle body vacuum lines.....
Then drove about 2 miles before the massive amounts of smoke were gone. Has to be the first time that was done to the car, but boy does she idle smoothly now. |
#2120
Added Stabil to the gas tank, ran the car 15 minutes and pulled the battery for winter storage. Previously ran the front tires up on two 2X8X24" to prevent the tires from locally compressing the macadam over the next 4-5 months.
Starting a subwoofer box for a cheap 12" sub. Want to get as much done this week as possible as it is not going to get any warmer in out work area (the great outdoors) for several months. |
#2121
Another annual application of Rust Check after installing the winter tires.
#2122
I bought 2 extra JDM BBS wheels to have as spares and put them over my workbench next to my OEM ones. In comparison, I can really see the difference in apparent size, even though they are both 16" Our massive 5 spokes actually look bigger than the fine mesh on the JDM. Must be the amount of metal that reflects light. Got 2 wheels, including packing and shipping from Japan for $150.00. Also ordered 2 spare center caps, in case I damage or lose one. Better to get them while they are still available. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
#2123
Put a Franken-motor in the old legacy we got for my brother, gonna do exhaust and brakes this weekend and it will be ready to go.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
#2124
Bought an SVX...
92 Silver 218K Km (135K Miles) Located in New Zealand First Post! :-) Daniel Parker |
#2125
Finally bit the bullet and painted the hood flat black. After years of trying to save the Carbon fiber look.
![]() And re cleaned the headlights... Got the new brakes on the rear ( calipers,pads, and slotted cross drilled rotors ) stops are smooth again. ![]()
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. Last edited by Conn SVX; 11-07-2013 at 06:32 AM. |
#2126
Expect to sell my first SVX tomorrow to someone flying in to see it. So today I vacuumed it and have assembled the service history documentation. A total of 13 years when I include docs from the previous owner. It appears that I'm the second owner in NZ. It was imported used from Japan (like most SVXs in NZ) with just under 100,000km on the odo.
Now showing about 162,000km so averaging perhaps 5000km per year. Both myself and the previous owner paid mechanics to work on the car. Interesting to note that most of the repair invoices are 2 or 3 pages. Almost none are a single page. Sad to see it go, it's the lowest milage of all my cars, has the best service history and is certainly feels much tighter than my daily driver SVX which is certainly showing all of it's 365,000km. But as I drive 30,000km per year for work on an assortment of crappy NZ roads I really want the extra safety of ABS & airbags which the car being sold lacks. So if you see Lachlan from Christchurch show up on the forum, please give him a warm welcome. And while I'm in the mood, welcome Daniel. You've got a nice car there and I'm sure you'll spare no expense restoring it to it's original condition. Shane |
#2127
Conn,
I think you should put a stock hood back on it, or maybe paint it the color of the body. It doesn't seem to be as nice as the rest of your car.
#2128
I don't have the stock hood. It may eventually get painted the car color
I just hit tires of it clouding up.
#2129
Conn, that hoods taking away from the rest of the car. Flat black looks good on a street rod, not our svx's. Get yourself a stock hood and paint it, you will thank me the next time we meet for coffee.
1995 POLO LSI 76K MILES SOLD |
#2130
