Old 10-31-2013, 05:24 PM
major7venth's Avatar
major7venth major7venth is offline
M7
Re: NO MORE CLICK click CLICK START..ONLY START! starter relay
Yeah, that works, tucked under the firewall real nice. I just prefer mounting where it is accessible and grounded to the battery.
Old 08-28-2014, 11:36 AM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
I've just read all the entries since this first showed up, and finally came to the definitive picture.... http://www.subaru-svx.net/forum/atta...2&d=1263144263
Unfortunately, it looks like this didn't make it to the "How To" area?????
I'm surprised nobody just said, "opposite the brake switch"... Oh well, it's found.
I had my engine out, and changed the location of the Ground wire, found just above the Starter, to bottom of the engine.
I had the click problem somewhat before, but it increased after putting all back together.
Today I will replace the relay, and find out if I have to look deeper.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 11-17-2017, 05:58 PM
simboglide's Avatar
simboglide simboglide is offline
I have no factory security system, therefore I don't have a relay there?
Old 11-24-2017, 08:37 PM
simboglide's Avatar
OK,,, been under the dash, no relay found, did the relay mod anyway, relay just clicks( no starting) I have the console out shift lock box is there ( totally electric, no adjustment there) small Mico switch as the base of the shifter seems to be doing it's job. I guess I'm reduced to the ignition switch??
Old 09-26-2019, 06:45 PM
theflystyle's Avatar
Necro-bump.
I finally got around to replacing this relay. I ordered the Bosch 0332204150 as mentioned on the first page and went under the hood to start the process. I quickly found the only relay attached to the steering column facing the passenger side, however it looked different than what I have seen in this thread. My "original" Bosch relay was teal and had the part number 0332204161 but was still a 12v 20/30amp relay. As I had the replacement on had I went ahead and performed the switch. The car started as expected but I wanted to post my findings here in case someone else has or had run into the same predicament. Please reference the attached pictures for clarification.
1994 SVX LSi
2008 Legacy 3.0R
Old 10-05-2019, 11:15 AM
RedLionSVX's Avatar
RedLionSVX RedLionSVX is offline
Great info!! Thanks for this.
Old 02-18-2021, 01:18 PM
depaz depaz is offline
Hola a todos desde España y muchas gracias por todas las aportaciones sobre este problema que afecta a nuestros vehículos.
Después de haber leído todo lo escrito en este lugar, relacionado con el mal arranque de mi SVX Red claret versión USA, y teniendo todos los síntomas aquí descritos y habiendo comprado y colocado un motor de arranque nuevo, reparado el viejo y vuelto a colocar, me decido a comprar un relé bosch para sustituir al que está colocado.
Lo sustituyo, doy al contacto y... click, click.
Toca revisar voltajes:
Cuando falla, en el motor de arranque hay 6,4 voltios, es mucha pérdida de tensión.
El esquema eléctrico del starter es muy sencillo, con lo que me decido a sacar el nuevo relé bosch otra vez de su hubicacion, pero con el trozo de instalación pequeño que lleva.
Ahí me doy cuenta de que el conector hembra de la instalación que queda en el coche tiene los terminales faston abiertos haciendo mal contacto. Los aprieto un poco y vuelvo a istalar el relé viejo, doy al contacto de nuevo y ... voila, arranca y arranca y arranca un montón de veces sin un solo fallo.
Le copio el archivo a Theflystyle para que veáis que es lo que saque junto al relé.
El terminal que apreté fue el que acopla en el blanco.
Old 02-18-2021, 09:27 PM
oab_au oab_au is online now
Good to see you got it fixed, yet another cause of "Click Click'.
One Arm Bloke.
Tell it like it is!
