Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 09-13-2013, 12:44 PM
Dessertrunner's Avatar
Front brake up grade to Wilwood 4 pot
Have removed
Old 09-14-2013, 01:13 AM
Re: Front brake up grade to Wilwood 4 pot
Have removed
Old 09-14-2013, 10:54 AM
bishop bishop is offline
whats with the extra 5 studs on your brakes? they look really good.
Old 09-14-2013, 11:54 AM
dragoontwo dragoontwo is offline
Looks like he's using wheel spacers.
'92 SVX LS Pearl White - 6mt
Old 09-14-2013, 02:41 PM
Have removed
Old 09-14-2013, 03:15 PM
SVX n00b
So what is the story with this? How did you find these calipers? What are the piston specs? Where did you get the caliper adapters?
Also, it looks like you had to clearance the OEM caliper mounting ears a little bit, any other massaging that goes with this swap?
Old 09-14-2013, 03:49 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Did you machine the adaptors or out source them ? Pad part number for the thicker type used?
Old 09-14-2013, 06:30 PM
oab_au oab_au is offline
You have to be joking to think Tony would get some body to make them.
Probably milled them up after dinner.
One Arm Bloke.
Tell it like it is!
Old 09-14-2013, 11:17 PM
Have removed
Old 09-15-2013, 03:44 PM
Originally Posted by Dessertrunner View Post
I can post a DXF file of the adapter if you want.
That would be great. Think the 4-pots would fit under 17" wheels? From pics they look like they'd even fit under the stockers. Those look great and I think for the price they should be a great upgrade.
Old 09-16-2013, 03:23 AM
Have removed
Old 09-16-2013, 04:48 AM
fasteract7's Avatar
Probably me not seeing the figure but what is the thickness of the adaptor?
Old 09-16-2013, 07:28 AM
Have removed
Old 09-16-2013, 05:56 PM
Could you make me a pair of the adapters?
Old 09-16-2013, 08:00 PM
steveherman steveherman is offline
Me too?
Maybe.
