Old 08-01-2013, 06:58 PM
FlipC FlipC is offline
Where to buy?
So I have to replace my rear cross member differential bushings.
Will check out that link thanks Blacky
Anyone got after market options
Old 08-01-2013, 07:05 PM
processengr's Avatar
Re: Where to buy?
Are you going to DIY? You have to drop the Diff to install the OEM...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-01-2013, 07:37 PM
Re: Where to buy?
The bushings that connect the diff member to the rear sub frame are:item#5
41322AA010 Bush Diff Mt F 2@$38.98 ea. http://www.subaruparts.com/diag/?mod...ategory=201-A1
Old 08-02-2013, 10:29 AM
Re: Where to buy?
Yes DIY
Im in the middle os a tranny swap. Going to a Legacy 4:11
The OG ones were being held in with silicone. Pushed right out with my fingers.
Thanks for the link Blacky. Least I know I can get the OEM ones.
Anyone got after market options?
Old 08-21-2013, 03:46 PM
Re: Where to buy?
So been busy just getting a chance to get back to this.
It turns out that is not the part I need. Having looked at the parts catalog (wuala) neither the 92-94 nor the 94-97 list the parts Im in need of.
The diagram doesn't show them.
having looked via Google Image I haven't found a single picture either.
So here are some pictures of what I need to replace.
Old 08-21-2013, 04:01 PM
Re: Where to buy?
The parts you want are: 41322PA000
Bushing Assembly, Differential Mounting, Rear
$36.72 each
PART 41326A in the diagram
[ MAIN ][ SVX ][ 1997 4WD ][ Engine Mount, Fuel, Exhaust and Engine Cooling ][ Differential Mounting ]
Old 08-21-2013, 06:26 PM
Re: Where to buy?
Sweet!
Thanks so much mate. Just noticed that little double dotted line.
Old 08-22-2013, 05:03 AM
dcarrb dcarrb is offline
Re: Where to buy?
As I recall, these bushings are curiously omitted from the subaruparts.com parts diagram for 1992; you have to look at a later model year.
dcb
Old 08-22-2013, 12:53 PM
bishop bishop is offline
Re: Where to buy?
Or you could grab some of these poly diff bushings.
