Old 08-20-2013, 04:34 PM
Quarter Panel Repair Discussion
I was discussing this with a bit with SVXCESS last weekend and it got me wondering more about what would be the best way to repair a rusting SVX Quarter Panel? Sanding and rust converter does not seem to be a fix.
If I found a rust free quarters on a parts car where would the cuts be made to to remove the part from the donor? Would it make more sense to order new ones from Subaru?
Seems like it is a common rust point but most bodyshops I've talked to won't guarantee a repair in that area. I don't know if they just don't want to do the work or if it would be so expensive as to not be worth quoting.
Old 08-20-2013, 09:03 PM
Tapani Tapani is offline
Re: Quarter Panel Repair Discussion
Are these available? Part number?
Thanks,
Tapani
Old 08-20-2013, 11:46 PM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Thanks,
Tapani
51410PA080 Right side 365.99$
51410PA090 Left side 365.99$
I found it on www.subarugenuineparts.com
http://opposedforces.com/parts/svx/e...llustration_1/
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 08-21-2013, 05:24 AM
dcarrb dcarrb is offline
They offer no guarantee because any repair that involves body filler is temporary, and doing it right gets to be costly.
dcb
Old 08-21-2013, 06:58 AM
dcb
I'd like to know what the step would be for doing it right.
Old 08-21-2013, 09:07 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
From what I gathered (since I have the same issue you do) there are spot welds that can be drilled out to take the whole quarter panel out spanning from door to trunk.
Mine started out from dirt accumulating underneath the rubber, mixing with water and salt until it ate itself from inside out. It might be worth giving a good rubberized underbody treatment underneath the fender liner when all is repaired.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 08-21-2013, 01:04 PM
Yes, they are available, however the labor involved is intensive for doing them properly and will likely result in many more parts being broken.
To be precise, to replace the quarter panel, the rear glass and rear upper glass needs to be removed along with the quarter garnish. Then drilling out a ton of spot welds on each side, then prying them away from the c pillars and other areas as well as making a few cuts. The best and cheapest way seems to be getting a patch panel from a parts car and cutting out the old and replacing with fresh metal that you can get at the backside and ensure no rust or possibly grind/wire wheel and treat any possible slight rust before the patch panel is put on.
Old 08-21-2013, 01:48 PM
Where would the cuts be made with this method?
Old 08-21-2013, 09:33 PM
There are many, many ways of doing it. Either just by cutting the affected areas, or many times I'll still cut out an entire rust free quarter, then allow the person or their body guy cut what they want.
Sorry to be so vague, but without being in person, and having a car in front of us, it's difficult to fully describe the many different possibilities. It would be a great conversation/explanation at Reading next year possibly
Old 08-22-2013, 05:14 AM
The temptation is to address rust perforation with a grinder and some body filler. That sort of repair could last for a few years, or a few months. Replacing the panel (or a portion thereof) as described above is the proper way to go for a lasting repair.
dcb
Old 08-22-2013, 08:03 AM
In my case I'll be replacing nearly the entire panel with a new factory one on both sides. The wheel arches are completely rotted, not just the corners. In addition, underneath the rear bumper and side skirts the metal is also severely damaged. My plan is to remove the factory welds along the door jamb, bottom, rear, and trunk, and then cut the panel on the B-pillar at the base of the window, and underneath the plastic garnish piece. By doing this I hope to ensure that almost all welds are in hidden areas, and reduce warpage in the panels from welding.
Old 08-22-2013, 11:53 AM
I wonder if I would be able to have a shop do the type of repair Crazy_pilot is describing?
Old 08-22-2013, 02:24 PM
It's very possible. Just finding a place to do it, and be reasonable about pricing is the trick. What he is describing is basically the best/most "reasonable" way.
Old 08-22-2013, 04:11 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
What Nate said!
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-22-2013, 06:10 PM
Green1995SVX's Avatar
No matter how you slice it, this is not going to be an inexpensive repair. I had my rust repaired in the way recommended by the others above.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
