Re: Antenna mast
Has anyone tried one of these rubber universal antennas:
http://www.rockauto.com/catalog/moreinfo.php?pk=262314
Re: Antenna mast
My local Pick N Pull has two SVX's with the power antennas still installed, if they're there tomorrow, I'll pick them up for whomever needs them
Re: Antenna mast
Sent you a PM. Definitely interested if they seem to be in good shape.
1996 SVX LSi : Work in progress, future garage queen 2013 Acura TSX: Mistake |
Re: Antenna mast
Seems like there has been a rash of car wash incidents lately!
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 05-21-2013 at 02:15 PM. |
Re: Antenna mast
Right. PM box. I may or may have not seen that I have messages.
![]() EDIT: One of the cars has been there since April 8th, I'm hoping that it is. If not, I'll only be able to pull one mast out ![]() Last edited by reberto; 05-21-2013 at 07:00 PM. |
Re: Antenna mast
