Old 10-01-2012, 11:53 AM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
Oxygen sensors, so many to choose from.
My 92 ebony popped an O2 sensor code yesterday. The check engine light was only on for a few minutes but I decided to have it scanned anyway.
I've seen prices ranging from $118.ea from subaru parts.com, to $80-ish ea from auto zone for bosch or denso exact-fit.
Is one better than the other?
Thanks.
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 10-01-2012, 12:15 PM
dragoontwo dragoontwo is offline
Re: Oxygen sensors, so many to choose from.
You can source an OEM NTK replacement from places like Rock Auto. The part # is NTK 24614. They should be around $37.79.
'92 SVX LS Pearl White - 6mt
Old 10-01-2012, 12:30 PM
I agree with the NGK/NTK sensors.
The most reliable, and the cheapest, O2 sensors I have found. Had them in since February 2010 and still perfect.
Amazon.com has them for $41.11
http://www.amazon.com/NGK-24614-Iden...ords=ntk+24614
NTK is the world's leading manufacturer of OEM oxygen sensors and supplies more vehicle manufacturers with oxygen sensors than any other company.
Old 10-01-2012, 12:45 PM
Huskymaniac's Avatar
Uses the ignore feature
I third this suggestion. I tried the Bosch with mixed results. My next sensor will be NTK.
Tony
Old 10-01-2012, 02:02 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Just make sure the O2 sensor has the plug on the end for easy replacement. Some cheaper versions don't have it and you will need to splice it.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 10-01-2012, 02:17 PM
The NTK sensor I listed does.
Old 10-02-2012, 12:41 AM
kwren's Avatar
kwren kwren is offline
The 02sensor may not even be bad...
Keith
Old 10-02-2012, 03:46 AM
Andrew P.'s Avatar
That is possible Keith.
But depending on how cheap I can get them for, I'll have spares if I need them.
77' IHC Scout SSII
Old 06-03-2013, 02:45 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
dumb question, but do all svxs have the same o2 sensors? the one listed above from amazon says will not fit my car...but a 96 is does. mine is a 94
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 06-03-2013, 03:26 PM
Blacky Blacky is online now
Yes they are all the same NTK 24614. Even the post cat sensor on the '96 and '97 are the same.
