If you were going to pull a 195,000-mile engine...
…in order to replace head gaskets, and planned to keep the car for another few years @ roughly 5000 miles per year, would you do just the obvious stuff (reseal kit, hoses and sensors beneath the intake, timing belt and tensioners, water pump and so-on), or go ahead with a complete rebuild? Engine is stout, doesn't burn oil, overheat, nor make scary noises. Occasional spirited driving but no abuse or triple-digit speeds in the past 40,000 miles. Budget is a definite consideration. I would be paying for trusted labor.
If a rebuild: rings, bearings… what else? Thanks, dcb |
Re: If you were going to pull a 195,000-mile engine...
How much longer before you pull the engine out? Something you could do is send in a used oil sample to Blackstone Labs to get an idea of how the bearings are feeling. When you pull the heads off you'll be able to tell what the cylinders look like. Honestly if everything looks good at that point I'd be on the side of leaving it alone and letting it roll on.
Unless there seems to be reason or symptoms that show signs of weakness, I'd leave it be and just take care of the top end. (or should I say the sides? ![]() They've been proven to last to 300k miles. (granted, some have also had issues around 100k) |
I'm not even certain yet that there's a head gasket problem; just pondering options. Heard a momentary gurgle under the hood after I shut off the car and saw that the coolant reservoir was filled to nearly the top and had "burped" lukewarm (not boiling) coolant. Cold radiator held about a half gallon, which would account for the amount over the reservoir "full" line. Coolant is clear, oil on dipstick isn't milky or weird, temp gauge is solid under all conditions. I've continued to drive normally (close to home) and have had no issues, but the reservoir sure seems to have a gasoline smell.
I don't have the dough to throw away on needless PM but don't want to be "penny wise and pound foolish," either. dcb |
Ans this was on a well-maintained 96 engine with 120,000 miles. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Same symptoms as mine.
Just finnished cleaning up te garage. Will start pulling the engine tomorrow. Hopefully will have a parts list by Monday ![]() Tapani |
