#31
Sorry, you have tried what I had tried.... anyone else want to chip-in ?.
#32
Re: idle trouble after deep puddle pass
I replaced the CTS a year and a half ago. Couldn't hurt to try again I guess.
#33
I replaced CTS last summer, its the last chance, yes.. I replaced throttle cable yesterday, so there is no sticking in the linkages Could IACV be still bad after cleaning? Resistance between 1-2 and 2-3 ~9omhs and green tab easy to move with screwdriver, no sticking..
Subaru SVX LSi `95 |
#34
If you can, replace the CTS first, $20 or so. If you have the money, buy a new IACV and the auxillary, then you know you would have replaced everything. Dont forget the hoses under the intake. Good Luck!
#35
The part of the throttle body I'm talking about is the part with the springs and stuff where the cable attaches to, not the cable itself. Check visually whether the throttle blades close fully. They should close all the way, or very close to it. Maybe you have a leak from a cracked vacuum line, that could cause a higher than normal idle. If the idle speed is high, then you have to be getting extra air, fuel, or timing advance from somewhere. Timing can be affected by the CTS or TPS. Fuel can be affected by the CTS, or by the wrong amount of air being measured (MAF), or the TPS. Extra air can come from the IACV, AACV, or a vacuum leak somewhere. Did you check the TPS voltage? Search the forum for how to check it, it's pretty easy with a multimeter and a couple of needles. I'd also unplug it and make sure the connection is dry.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#36
In case it has begun immediately after i had passed deep puddle, the problem probably in parts, which could be damaged by water: air filter - MAF - IACV or AACV i guess.. Could TPS be damaged by water in intake boot? All the more CTS...
#37
It's a stretch, but if water got in the plug connection, it's possible that's the problem.
#38
I know this sounds elementary, but have you reset the entire car by unplugging the battery overnight? My car was having a terrible idle recently, threw a code for the EGR (34), left O2 sensor and then the TPS and MAF (but the last two were because I had taken them off to clean them). I unplugged it overnight, started it the next day, threw no codes at all (yes, I checked with the blue wires into the black connector - nothing) and the idle was actually better than before. It wouldn't hurt to try
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
#39
#40
OK so the air is not getting in through the AACV unit. Next disconnect the air pipe that runs from the air delivery tube to the IACV. It is a bigger pipe connected below the air delivery pipe. Block the hole in the air delivery pipe, and then start to cover the end of the pipe to the IACV, to see if the engine slows as you reduce the amount of air that can get to the IACV. This will tell if the air is getting through the IACV or from some other source. Harvey.
#41
-Hole in the delivery pipe blocked, end of the pipe to IACV open fully: engine runs for 5 seconds, then car dies. its like 1500rpm, 1200-1000-800-600-300-dead -Hole in the delivery open, end of the pipe to IACV open fully: the same, but car die faster -Hole in the delivery blocked, end of the pipe to IACV blocked: it sucked my finger and die too
#42
So either the IACV is not responding to the signals the ECU is sending, (stuck, jamed or the windings in the valve are open). Or the wiring to the valve is open ( not connected properly). Harvey.
#43
Maybe i left wrong space between tab and body before installing it back to TB? I left 4-5 millimeters, like here:
#44
The amount that the valve is open there, looks like it is about right, but I have not had one off to see. This is a pic of one that is about right so it looks the same.
http://www.subaru-svx.net/forum/atta...4&d=1193385499 So the valve maybe set right, but the ECU maybe holding it open for some reason. Do you think you could pull the plug off the valve when it is idling fast, to see if it slows down or stays the same. That will tell us if the ECU is holding it open for some electrical reason? Harvey.
#45
