Factory audio setup?
Since I hate having an ugly single DIN JVC stereo in my SVX, I was planning on swapping in something different to help fill up that space. I was thinking of installing the CD changer out of an 00-04 Legacy/Outback (this one), adding in the CD changer to AUX adapter, and if possible, installing the factory subwoofer that Subaru offered with that stereo (this one)
To all you audio/late model Subaru experts out there: do you see any problem with this setup? I will be getting the SVX to 14 pin adapter to go along with it so it should just be plug n play? Thanks all! |
Re: Factory audio setup?
If you buy the factory sub, don't pay very much for it. It's subpar.
I slay me.
Any other advice on tackling this?
for low impacts on cargo space i suggest looking for the write up someone did on a sub in the spare tire well. Or I put a small bass tube behind the drivers seat.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black 92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho ![]() |
That would involve adding an amp though, correct?
Yes it would. There are probably some built in options but the amp I got fits under the driver seat easily.
That's what I was hoping to avoid. I personally can't stand aftermarket audio like that, which is why I was wanting to do an underseat one from Subaru, as that can be installed with a simple adapter.
As long as you don't expect much from it, you'll be fine. They're really not worth the time. Get some good speakers for the existing locations and you'll be leaps and bounds ahead of what that little box will get you, and with less effort.
PM'ing you now reberto
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
