Roll Cage in the SVX
Who out there has a roll cage and harness bar? Any pics? I really want to add sports seats, maybe Cobra Daytonas or Bride Eurosters and 5-point harness. I don't want to do that without a roll bar. I'm thinking a 4-point bar, braced against the body on either side of the rear seat and a removable harness bar. This set-up would still allow some access to the rear seat.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; 07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Re: Roll Cage in the SVX
Ask benebob. He had one installed in his 92 pearlie race car.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member 2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Ask Hocrest, he has the link for the maker. Measurements were taken from his car so it should fit in a full interiored car. Biggest problem you'll have is welding it in with the interior in and once its in having head room.
![]() If you're coming to Reading see if OT is bringing the car up or not. If not I'm sure you could twist his arm into some pics of it.
Are you looking for a structure that is simply there to support the seats and harness? Or are you looking to build it to the specs of a race sanctioning body? Do you want it for the look, or functional? Di you plan on driving this car in the street? How tall are you?
There is a variety of designs you can choose from to meet you needs. The biggest problem of our cars is the lack of head room. You Best bet is to bend up a main hoop that goes just behind the B pillar, then ties into the rear strut towers. This will be a sufficient roll bar with the ability to keep the roof from crushing in, and mount your harness straps to. If you daily the car, avoid roof bars that run by the doors. If you ever crash, you likely to crack you head open on these with out a helmet on. |
I am not looking to meet any sanactioning body race regulations. I plan on driving the car on the street and don't want or need the door bars. I want to have a 5-point harness, but I realize they make you very vulnerable in a rollover if the roof collapses. I've seen a lot of advice that says don't do 5-point belts in a closed car unless you have rollover protection.
I was already thinking of having the roll bar run up from the floor just to the rear of the door opening. It would continue up, slanting toward the back to follow the B-pillar. I need the top of the roll bar to be well behind the front seat back, as I am very tall. I was thinking that the two braces could tie into the strut towers and I wouldn't have to tear up the rear seats. Not looking to do a diagonal unless it is bolt in along with the bolt-in harness bar. Either of those would preclude access to the rear seat, which doesn't matter on the track, but is useful on the street, even if there is only room for one person with the roll bar and supports to either side.
Gotcha. Sounds like you already have a decent plan of attack here. Just use at least .120 wall tube, (DOM only) and you will be good to go for rollover protection. The SVX has a good b pillar structure as it is. As for you height, if your going to be the only driver, you may want to consider bolting you seat directly to the seat rails and loose the slider. That will drop your butt a good 3" and give you a better seating position. More room for a helmet as well if you autocross.
![]() If you are welding the tube into a corner, use this boxing method as it is far stronger than just welding to the floor. ![]() Last edited by smc; 03-04-2013 at 07:37 PM. |
smc:
Those photos aren't from an SVX, are they? Haven't ever seen an SVX inerior stripped naked, but, this geometry doesn't look right. By the way, any opinions on my seat choices, Cobra Daytona or Bride Euroster? I think they will result in a significant drop in seat height.
One is an impreza, the other is a bmw. It just what I could find in a quick
And if you ever get a fixed back seat, I would HIGHLY recommend Momo seats. I tried a few different seats over the years and momo was by far the most back and tushy friendly of the racing seats.
Here is the Bride seat. It is in suede, or pseudo-suede.
![]() Here is the Cobra Daytona. It is cloth. ![]() Will have to get either equiped with a penetration for the 5-point harness.
My car is caged...but wasn't done by me...is there anything I can measure that would help?
m |
Any pics of the roll cage?
Some picts here, from his Gravel rally car.
http://www.subaru-svx.net/forum/show...9&postcount=13 Harvey.
probably a little more invasive than what I had in mind, but, thanks for the pix.
