#31
Re: '92 AWD Partout
huh, OK. I didn't even realize that was a separate piece.....I don't think it's been pulled off the shell yet, I'll pull it the next time I'm out there. Hopefully later this week.
#32
Re: '92 AWD Partout
Thanks very much!
#33
Re: '92 AWD Partout
Do you have the Drivers Front window regulator?
This pic is of the passenger side, but I need the drivers. My window motor is fine, but the cable on the regulator is shot. I only need the cable if you are willing to part it from the regulator. I live in Canada, so shipping size/weight/cost is a consideration. |
#34
Re: '92 AWD Partout
Re: '92 AWD Partout
Say,
Would you happen to have the ABS Sensor for the Drivers side Front wheel? Thanks for checking. |
#36
Re: '92 AWD Partout
Got my trim piece, thanks very much!
#37
Re: '92 AWD Partout
Curious if the following parts are still available...
Driver's side wiper arm and the pivot piece under the cowling that sweeps it. Mine is stripped and won't sweep the arm anymore. Driver's side sun visor if it is in good shape. Mine is bent, and sags, and only stays put in the forward position. Driver's side plastic door sill plate, hopefully with some of the body clips and attachment posts still intact. Mine has all of the posts broken, and won't stay in place any longer.
"What you plan, and what actually happens ain't exactly ever been similar..." ------------ 1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it. 2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan. 1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun. |
#38
Re: '92 AWD Partout
Do you have the differential/rear end?
