Re: '92 AWD Partout
Need the driver's side passenger window let me know...
Never mind Insurance company will replace no-deductible...
HENRY 92 SVX Claret(No More) 12 Camaro ZL1 89 Yamaha FJ1200 07 Yamaha FJR1300 "GO RAVENS" Last edited by rvnmaniac; 11-15-2012 at 06:24 PM. |
Re: '92 AWD Partout
Bump
Lights, gauges and climate control on ebay: http://www.ebay.com/sch/numbchuxsoad...&_trksid=p3686 |
Re: '92 AWD Partout
I see you have some XT6 stuff. Got any XT6 power steering stuff?
Re: '92 AWD Partout
What are you looking for? I've got a pump that needs brushes....not sure I'm willing to sell it though |
Re: '92 AWD Partout
I can keep an eye out for this stuff as well. Had I known, last time I was at Harry's, there was an XT6. Not sure if I'm heading there this time or one of the other yards, or if it's even still there.
Re: '92 AWD Partout
^ Thanks Nate, keep an eye out. If you see it grab all of it. It's got an electric power steering pump. The lines might (I don't know) match up with the SVX steering rack. (Or I could have lines made that do). An MR2 power steering pump might work too, if you can grab one cheap.
I don't know what it looks like, or if there's a separate reservoir or what, but I know that either there's a control module for it, or it's controlled by the ECU or both. So I'd need those too. The high pressure line(s) for sure I'd need. The low-pressure lines I don't need if they're just generic ATF lines like ours, but I do if they have fittings. Don't need the rack. Numbchux, just the pump would be a start. Where do you get brushes for one? Any info you know about the system would be good too... Like whether it's controlled by the ECU or what. The idea is that I could clean up the engine bay some more by switching to an electric power steering pump. Gotta make room for a turbo and piping somehow, right?
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 11-19-2012 at 03:10 AM. |
Re: '92 AWD Partout
I started posting a reply here....but it turned very long. So instead of hijacking my own thread.....I'll start a new one.
http://www.subaru-svx.net/forum/showthread.php?p=715897 |
Re: '92 AWD Partout
#2 on this diagram (but for passenger side )
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
Re: '92 AWD Partout
hood shocks any good ??
Re: '92 AWD Partout
Afraid not |
Re: '92 AWD Partout
Any condition is fine, as long as it's intact and will bolt up to the body.
Re: '92 AWD Partout
Dirty, but in great shape. All mounting holes in tact (hardware got lost in the partout, though...but it's just nylon rivets and a few bolts), just have to throw it in a box and ship it to you. PM me an offer so I don't forget again Made it through the Holidays.....anyone else need anything? All the available exterior lighting has been relisted on ebay: http://www.ebay.com/sch/numbchuxsoad...p2047675.l2562 |
#28
Re: '92 AWD Partout
Do you have the trim piece under the window on the passenger side? Mine had an 'SVX' logo that disintegrated but it also ruined the paint. I know they are tough to get off, but should the clips break, I'm sure I can find alternate means of re-attaching it.
I'm in New Hampshire, zip 03859 for shipping quotes. Thanks! Brian |
#29
Re: '92 AWD Partout
Re: '92 AWD Partout
It looks like this, but I need it for the passenger side:
Thanks! Brian |
