Old 10-20-2012, 09:31 PM
processengr's Avatar
Re: Wheels that fit the SVX
Mazda RX8 wheels are one of my favorites...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 10-21-2012, 09:25 AM
Ok confused as always.. 5 114. And 5 114.3and 4.5 inch are they all compatible? Looking at Mazda wheels with 5 114 bolt circle. Also if hub size is only slightly larger , I can't use the ring spacers. Will it work only using the lug nuts to keep rim central?
Old 10-21-2012, 09:34 AM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
I believe all those measurements are the same. 114.3 is often abbreviated to just 114, and is the same as 4.5 inch. Hub-centering rings come in many different sizes; you may be able to find ones to fit, but I've never looked for ones that adapt a Mazda bore to a Subaru one. You can bolt it up to be lug-centric, you just have to be more careful when tightening the nuts to avoid any vibrations.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 10-21-2012, 12:05 PM
Mazdas are good crossovers with very similiar offsets. The Mazda 3 wheels are not very wide compared to ours but that is a plus for snow tires. Mazda 6 wheels are in general wider but still not as wide as our. The Mazda center bore is 67.1mm and the Subaru is 56.1mm. Hub centric rings are cheap and will help make the wheel sit better.
Old 10-21-2012, 04:30 PM
Just thinking 56 to 67mm is 10 mm that is a 1/4 inch total or 1/8 on a side. Do they make them that thin. I have rings on my mags now. Would be great it they were the right size. They are thin. Maybe the PO remembers?just checked yes they do make them 56.3 to 66.7
Old 10-23-2012, 09:21 PM
mkud28's Avatar
mkud28 mkud28 is offline
I am going to have to roll the fenders but I believe I can make these work once I can buy some tires.
Old 10-23-2012, 09:56 PM
What brand/model are they?
Old 10-23-2012, 09:57 PM
So when are you going to buy some tires? You have had those a while now haven't you?
Old 10-23-2012, 11:53 PM
mkud28's Avatar
Yeah I had to buy tires for the daily first, which then blew up on me so that is more money. I have been poor as of late. I am hoping very soon I can get tires and they are enkei rts 17x8.
Old 10-24-2012, 04:45 AM
I still think you will have trouble with rubbing but I'm very interested to see what they will look like mounted on the SVX with tires.
Old 10-24-2012, 10:31 PM
mkud28's Avatar
Yeah I am a little worried about rubbing, but that is mostly due to how low my car is. I hope to rectify that some as well. It is too low, lots of roads are crappy down here.
Old 10-26-2012, 05:37 PM
Question : where do they come up with the offset #? So I measure and I get 6" no amount of calculating get a 45 . Bolt C 114.3 is 4 1/2 " and the center is 56 a little over 2" makes sense . 45?
Got my answer : you have to measure the wheel width divide by 2 then measure the distance to the rear of the rim to hub and subtract it from that figure . 45mm is 45mm from centerline
Old 11-01-2012, 06:36 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
-Dustin
Old 11-30-2012, 11:33 PM
gjhumphris's Avatar
gjhumphris gjhumphris is offline
I'm looking at changing my wheels and have found a design I like on ebay. I have read thru a lot of this thread, but just want clarification please??
The new wheel size is 17" x 7.5"; 5 x 114.3; 225/45/R17 tyres; BUT +38 offset.
According to wheel offset calculators, this means the wheels will sit 17mm further from the calipers and 17mm towards the outside guards. Will this fit WITHOUT rolling in guards / using camber bolts?
Here is the design ...
http://www.ebay.com.au/itm/17-MAG-WH...item4abf1a49c2
Thanks!
Old 11-30-2012, 11:36 PM
92 SVX 92 SVX is offline
Thanks!
with a 7.5" rim that should work just fine, though how it will affect stress on the bearing I do not know.
