Old 10-17-2012, 11:03 PM
ssenter ssenter is offline
Possessed Panasonic CD player
I recently acquired a '92 SVX w/factory Panasonic am/fm cassette and separate CD player. The CD player has a mind of its own, turning on and off randomly, looking for a disc. Of course when it does it, the radio cuts out too. The worst problem, is that it will do it regardless of whether the radio is on---meaning it will do it when the radio is off and/or car is turned off, potentially draining the battery. It does seem to be temperature sensitive, i.e. the warmer the components, the greater the frequency of problem.
Anyone ever had this problem? How hard is it to get to the wiring harness to unplug the CD player?
Thanks a bunch!
Scott
Klamath Falls, OR
Old 10-18-2012, 12:42 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Re: Possessed Panasonic CD player
The factory CD player is getting a little "long in the tooth," so it's no surprise that yours is flaking out. Sounds like a problem with a switch that detects when a CD si inserted. I think the unit will let you insert or eject a disc at any time (even when the radio and car are powered off).
It's not that difficult to pull out the radio and CD deck. See my SVX Audio guide.
David C.
1996 Laguna Blue Pearl SVX L AWD
See my home page for SVX radio install/removal instructions and wiring harnesses
