60-0 distance?
I just saw this 60-0 distance of 98ft for the SVX, in Wikipedia
I'm finding that hard to believe, since a STI with Brembos does it in ~110ft how big of a lie are we talking about?! my guess is that it actually does it in 120-130ish...anyone tested that?
DIY FTW! 1993 SVX 25th Anniversary Edition @+142k -Rebuilt Tranny @135k -Regasketed Engine @140k -Enkei Raijin 18x8.5, with 255/35/18's @140k -BC racing Coilovers (From STI's) @142k |
Re: 60-0 distance?
Motorweek did a full report on the SVX when it came out in late 1991. You can see the entire episode here We are not talking a lie at all. According to the Motorweek road test, the 60-0 brake time was indeed only 98 ft. Here is a screen shot of that road test. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-21-2012 at 11:50 PM. |
Re: 60-0 distance?
I have seen that, and I also have seen that other more recent review that talks about the braking performance being bad and needing an upgrade.
I personally can't see the SVX braking as good as these, specially being so heavy ![]() or that's just me...thanks anyways
Re: 60-0 distance?
Believe it. Hell, check out the end of my video. 80 mph to 0 in just a tick over 100 feet. Stock brakes with stock rubber brake lines. Just some good pads. A good rule of thumb. If you lock up your tires, then you dont need bigger brakes. I had to modulate the brakes a good deal to keep from locking up.
http://youtu.be/6A7wND9oibk Last edited by smc; 06-22-2012 at 12:27 AM. |
Re: 60-0 distance?
I'm rarely in the pedal area where it actually bites but it does bite when you really kick the pedal. I've got EBC discs (vented all around) with greenstuff and when I went for a brake test I didn't even want to do a full emergency stop because it was very uncomfortable
![]() "other reviews" probably complain about the brakes because they're not really so great for racing. Unless you really put effort into it, the SVX is not a racing machine (and if you turn it into one you will upgrade to much harder brakes). It's got stopping power, maybe that explains the not so uncommon warping.
I got my girl, I got my glass, I got my car and I'm ready to f... |
Re: 60-0 distance?
I'm not one to do brake tests and I fortunately had to panic stop just once, and in that, I experienced 2 seconds of interrupted brake locking but I never imagined that it could be that good at braking...hell, I still have trouble believing it
![]() ![]() ![]() that's a good explanation for the disk warping situation... ![]() Thanks guys
Re: 60-0 distance?
The Myth of the Warped Brake Rotor Having a clean mating surface and the wheels mounted and torqued correctly and uniformly are very important, but uneven transfer of brake material is the major cause of the vibration. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-22-2012 at 05:44 AM. |
Re: 60-0 distance?
60-0 in 98 feet does seem awfully hard to believe. You're talking deceleration on the brink of 1.2g on civilian all-season tires?
![]() I have no idea who Gil is, but the numbers posted <here (cars101.com)> 70-0 lean more toward 170. That would make a good share of sense when compared to the number posted <here (TampaRacing stats quoted)>, 134.
Re: 60-0 distance?
^ I miss Tamparacing..
http://i840.photobucket.com/albums/z...93705d9zzz.png |
Re: 60-0 distance?
The SVX thread on the TamponRacing site is a real hoot. Sooo much misinformation from those who did little research its ridiculous.
I like this quote : "Car was designed by subarua with motor & all, but had some input from mclaren. Window design was from mclaren, supposed to be beneficial to get minimal wind buffer & rain in when having the window down." ![]() No mention of Giugiaro ![]() .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Re: 60-0 distance?
Tampa racing is full of 'tards. Packed, even. Highly un-recommended.
Re: 60-0 distance?
Exactly why I miss it.
Re: 60-0 distance?
Re: 60-0 distance?
Re: 60-0 distance?
