#121
Re: Engine Bearing Failure
Correct me if I am wrong,
If you intend on running a suction from each rocker cover you will need more then a 5 rotor pump as you will need 2 rotors for the sump (some are using 3 on 4 cyclinder engines) and 2 for each head. That only leaves 1 for the rest of the job. So if you want to run a oil cooler etc or 2 rotors to the pressure side its not enough. What ever happens you need to be supplying the bearings with more then the existing pump. My question is have you worked out the circut for the plumbing yet if so how many litres per minute are you aiming at suppling to the bearings. From what I can see the Cosworth dry sump is by far the simplest. Tony
#123
Also the plate over the top is very simple.
Tony
#124
I'll most likely stick with the stock oil cooler and then even if it's not enough I can easily reduce the water temp going through the oil cooler cool the oil more - currently it receives water probably around 75'C ish after flowing from the pump along the lower water pipe within the engine... drop that water feed into the oil cooler to 25'C and it's a huge difference in cooling effect. Obvious a few factors as you don't want cold engine oil - but you get the point. Also given I'll have around 12L of oil in the tank/engine - that's a lot of oil to keep warm and also a lot of surrounding aluminium to keep warm - the aluminium will suck a ****load of heat out of the oil, plus given the pump is far more efficient it won't heat the oil up like the stock pump does at high pressure. |
#125
#126
The one concern in the back of my mind is what is the maxium oil flow that can be pumped through the motor.
My logic for asking you about the different pressure at different revs would tell us the amount of oil that can be pump throught the existing system. In simple terms if you find the point at which the oil presuure fails to increase inspite of increase reves then using that rev number we can calculate the amount of oil the system can handle. Also don't know if we have all agreed but it seems that high clearance on the bearings is far better. Is that accepted or not? Tony
#127
If the flow is reduced as it flows through the gallery and the holes through the crank, then the pressure won't help. There has to be enough flow to cool and lube the big end. Increasing the bearing clearance will be detrimental if the flow can't keep up the supply, the oil will fling out of the shell faster that it can be supplied. Look at the way the oil has to flow from the gallery, to the main bearing cap groove, into the main journal, through the crank to the big end shell, it's not just a pipe! Harvey.
#128
Have done the DXF of the sump plate for the dry sump so if anyone wants one let me know.
Tony
#129
Here is draft sump pdf itss #D so double click and you can rotate to see the under side. As I say its a draft so all input appricated.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 06-02-2012 at 07:40 PM. |
#130
Maybe you should make the fittings for the lines come out of the side, rather than the bottom. God forbid it gets snagged on a rock or something. Or maybe it would still be too high up for that?
#131
Did draw it from the side and it just didn't look right but your point is correct. The bolt on bit is 50mm deep by putting the entry into the base I should be able to cut it back a bit.
Tell you the truth I haven't got a clue what I need and don't need all sorts of questions come to mind like, How much volume does the well need to be? Should I make it 2 sections (maybe yes so one put rotor doesn't run dry)? Why do they ghave two suctions? Counting the head suctions you are talking 4 suction is that what is needed? What do you do with the exist pump? so help. Tony
#132
If you used an external pump, to pump from your sump, to a tank, with gravity feed to the orignal pressure pump, it would solve the surge problem. Whether this will fix the bearing problem or not will be seen. Harvey.
#133
That is absolutely brilliant mate - I'm in awe, really top stuff
#134
When I designed the main plate on the dry sump I have a 20mm slope so the oil will move away to the suction resonablly fast. Due to the viscusity of oil it doesn't move fast on a flat surface. Looking as all the current dry sumps aviable for the EG33 they are flat from the edge to the centre.
Further head thoughts. 1 - We have the ability to fin the outside of the sump to enable some cooling of the oil by the air passing by. This will require no more material it would mean less cnc cutting. Do we want to design this feature in? 2 - I understand why there is 2 suctions in the sump. The pressure side of the dry sump pumps is often bigger then the single suction side. Also the return oil has great volume due to the amount of air present in the oil. Therfor there is a risk of the amount of oil increaseing in the sump and getting up to the crank etc which could kill the engine. We have to have 2 suctions. 3 - Need to have a baffle between these suctions so both lobes get feed oil otherwise one might run dry then it would lock up. Baffle in dry sump well needed. 4 - The well has to be high enough to hold small surges of oil while the pumps catch up. The size I have is enough, in the case I need more its just a matter of replacing the bottom section of the sump. 5 - Give suction in each head and two in the sump plus one pressure pump I need 5 stages. 5 stage pump it is just as bazza said. Question I don't have a answer for yet, What pressure do we supply? What volume of oil do we need to pump? Were or how will we fit the pressure relief valve? Do we remove the existing pump (I feel the answer is yes)? How do we drive the pump and from were on the crank? All suggestion greatly appricated. Tony
#135
Alum plate to make the dry sump will cost $300. So now just need to decide if I am going to build one.
Tony
