Old 04-12-2012, 08:12 AM
Applied my 3 coat of leather treatment to the seats. They are at least twice as playable as they were before treatment . Very pleased .
Old 04-13-2012, 11:01 AM
Green1995SVX's Avatar
Today I replaced the o-rings in my AC system and recharged it. When we did my 5 speed swap, all of the original R12 fell out when the engine moved a bit. I have some R12 that I'm saving for a rainy day, but I still decided to convert the system and run R134a. All is well!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-13-2012, 11:35 AM
I may start mine this weekend as it will be warm finally. Did you remove the seats or do it in the car
Old 04-14-2012, 01:13 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Washed & waxed both today...
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-14-2012, 01:23 PM
SpecialFX's Avatar
SpecialFX SpecialFX is offline
Replaced the shocks on the trunk. No more having to hold it up or worry about being decapitated!
Old 04-14-2012, 03:43 PM
Exclamation Re: What have you done to your SVX (or other Subaru) today?
I have been doing it in the car? I left each coat on for a week . Days have not been really hot.
Old 04-14-2012, 04:08 PM
SVX_MY_BABY's Avatar
I'm not going down that road!
Peter
Old 04-14-2012, 04:53 PM
Did you wrap them in plastic?
Old 04-14-2012, 06:27 PM
No but I am going to clean them and the last application will be in plastic. I figured it gets hot inside the car ( needs heat )and I have to use the car for work when it doesn't rain.
Old 04-14-2012, 07:37 PM
Thanks Conn. I am going to put on the first application tomorrow.
Old 04-14-2012, 08:48 PM
Rod.'s Avatar
Rod. Rod. is offline
Finally put on the new badge:
Rod.
'97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD
'92 Ebony LS-L #6851, USDM (sold)
'08 Forester (wife's)
'06 STi (traded for the Forester)
'94 Legacy wagon (sold)
Old 04-15-2012, 12:44 PM
Obewon Obewon is offline
Just washed and waxed it. Trying to ensure it is washed at least once a week all year, in celebration of it being 20 years old this year.
It's a beautiful car.
92 SVX, Ebony Mica 186,000 kms
92 Mercedes Benz 300CE, Arctic White 187,000 kms
Old 04-15-2012, 02:51 PM
Tried to pull it into the garage to get the restoration started but the battery is kapuuuut and my portable charger is kapuuuuuut.
Old 04-15-2012, 07:18 PM
Yesterday, had to drive up to Covington, KY to do a clutch job on my daughters Impreza RS, so she'd have transportation, then got home today and replaced the timing belt and water pump on the Beater Forester I picked up for a DD....I'm wore out.........I need a weekend to recover from my weekend....
Old 04-15-2012, 08:31 PM
Swapped in my ZX2 battery and crank it about 10 times with about a minute pause in between until it started, let it run until all the vapor stopped coming out of the exhaust (turns out there was some water in the engine) and strong-armed it into the garage whereupon I managed to remove every bolt from the control arm and ball joint minus 1 that is contorted in such a way it won't come out with some cutting or bending.
