low voltage at purge solenoid
Hello.
I have a 94 SVX LSi AWD. It has a 4.44 tranny in it now. I also have the EcuTune Stage 1Av1 and the TCU computer. My check engine light is on for the purge solenoid valve. I have checked the voltage at the plug and coming from the ecu and it is 3.7 volts constant wether the CEL light is on or not. I do not have the wire from the 1Av1 connected. Any ideas why I'm only getting 3.7 volts? This is my second SVX. My first one was a 92 LSL?( Been 10 years) It was 2 tone silver and black. |
Re: low voltage at purge solenoid
The voltage that is sent is a Duty Cycle, that won't be a constant Voltage. The code says that the wiring to it is either open or shorted, or the solenoid is not responding to the signal. Harvey.
So the solenoid , when it is supposed to turn on , should be getting the 12+ volts it's supposed to. If I'm only getting 3.7 volts constant wether I'm idling or driving then my ecu is messed up, correct? Just to clarify, I'm getting the 3.7 volts with my car at normal temps.
you could be measuring the voltage drop over a corroded wire. check the voltage at the computer itself.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
From the other side of the solenoid to ground you should get 7V min. This just checks the power supply, and the solenoid winding. The actually signal level when operating varies from 10V to zero. It only works when the car is cruising, on a light throttle, as it is sucking fuel fumes into the engine. Harvey.
Ok. I will look into it more this weekend . Just one more quick question. What pin number is the blue/red wire when it goes into the ecu at the yellow connector b61? It's 1 thru 16 I just don't see a blue/red wire on it.
Thankyou for the help so far guys! ![]() |
Thanks! ![]() |
Sorry about lapse of time, but I finally got to checking things out. It looks like it may be my ecu that is the problem. I'm going to get ahold of another one in a bit and then I'll know for sure.
It was definately the ECU. Hard to ignore the smell of burnt electronics. The new ECU works great. Thanks for the help.!!
Thank for letting us know.
![]() Harvey.
