Old 02-01-2012, 10:02 PM
This.
(profanity)
Enjoy.
Old 02-02-2012, 11:15 AM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
@NikFu - what kind of tires do you have on that thing? It is a fairly steep driveway though I'll admit, I was really expecting you to make it up there!
1994 subaru svx le 112k
Old 02-02-2012, 01:07 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Shoulda turned the rap off - then you would've made it
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 02-02-2012, 01:56 PM
Subix's Avatar
No no, he was tackling it like a Thug and had the appropriate music on (I kid) perhaps the track should have been something far more aggressive however
Old 02-02-2012, 03:08 PM
92 SVX 92 SVX is offline
put new rims and tires on, will have pictures later.
Old 02-02-2012, 08:38 PM
Generic ones, I think. I bought these tires with the Honda wheels they are on from some guy with an Accord. Being that they came from a FWD the wear is uneven. They also have different treads, which I had to point out to the guy. Knocked $60 off his price.
Well, someone is a music prude.
I actually did try the hill again today with different music on and I made it up, so maybe you are on to something.
Old 02-02-2012, 08:45 PM
Jay Wrix Jay Wrix is offline
made my non exsistant exhaust beautiful again
and dis assmebled wheel bearing, sent hub to the shop. broke my abs sensor =/
fixed power steering leak.... AGAIN
Old 02-03-2012, 12:24 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Put my new Maniac alternator in! I couldn't unbolt the tensioner... I was starting to round the bolt off. But, using my resourceful, pre-engineering skills, I was able to get it off anyways! I just unbolted the alternator, pushed it down as far as I could, then used the slightly larger amount of slack to push the belt off one tooth at a time, by turning the alternator pulley. It worked! Got the new one in by the same principal, and then used the leverage from that final screw to put the tension back to normal.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 02-03-2012, 05:08 AM
What happens later when you need to change the belt?
Old 02-03-2012, 07:26 AM
as mentioned here are a couple of teaser pics of the new rims Will get better pics after washing and finding a good background.
these were taken with my cell phone.
Old 02-03-2012, 07:30 AM
B 4 You's Avatar
#lolsvx
I take it to a garage, and let them handle it.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 02-03-2012, 07:50 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Had the pleasure of driving it in first and third gear only :/
Frantically trying to source a 4.44 tranny.
Old 02-03-2012, 08:22 AM
or spend 20 bucks on the stretch belt tools. they are meant for installing the stretchable belts on new subarus. looks like two little shoe horn things, one takes the belt off and one installs it. they work great when you just can't get enough slack.
I have these but the cheaper one is the same idea.
http://www.google.com/products/catal...ed=0CCYQ8wIwAA
Old 02-03-2012, 01:47 PM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
I like them. What wheels are those? Rotas?
Old 02-03-2012, 02:11 PM
B 4 You's Avatar
#lolsvx
http://www.youtube.com/watch?v=uGJCtWKkaTE
Didn't know they had these!
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
