Window problem
We took the SVX to Florida over Thanksgiving and I ran into a bit of a problem.
I was trying to run the driver's side window down to mention something to my wife in the motel parking lot, and the window went down about 3 inches and stopped. It ran back up just fine, and I tried again several times with the same result. I cycled the window lock button just our of frustration but nothing would allow it to go all the way down. Not wanted to press my luck with having it STAY down, I didn't mess with it again since then. Any ideas? Thanks! Don
Cats: Clio, Inky, Sheba, Sparky, Rocky, Cali, Scooter 3 cars: 02 SVT Focus, 2012 Versa...2015 Fiat 500 currently SVX-less 1 wife ("She, who must be obeyed..") "One advantage of being disorderly is that one is constantly making exciting discoveries" |
Re: Window problem
when mine did that the cable had slipped out of one of the wheels because a little plastic collar that feeds it into a tube had cracked and dislodged it.
Re: Window problem
Watch out. Mine did that then it separated and dropped. Its pretty easy to take the panel off and see what the issue is. For mine, I need to get the lefter mechanism about $150.
Good luck and hopefully its an easy fix. Cheers, Adam |
Re: Window problem
Thanks for the help guys! Does anyone know the part number for that plastic sleeve thing? Jerry could help me take the door apart this weekend if I can get the right part to fix it with...
Don
Re: Window problem
i bought a used regulator/motor to avoid messing with it in the future but have used a home made plastic sleeve that i made out of a pen case with some success.
Re: Window problem
Post with photos and written instructions can be found HERE. Order a couple to have on hand in case the other one goes. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-06-2017 at 01:16 AM. |
Re: Window problem
Thanks John!
Don
Re: Window problem
Drove up to Jerry's on Saturday, since he had experience with taking the door apart, and we made an interesting discovery.
It was not the sleeve lock regulator at all.....the cable had somehow slipped to the INSIDE of the regulator bracket and was stopping the window after about 3 inches of downward travel. It seemed to have a bit too much slack in it, but it still took a bit of effort to make it get back out of position again, and neither Jerry or I could see what would have made that happen. He discovered something that seemed to be a tightening adjustment in the lower front and succeeded in taking a bit of slack from the wire, and then we discovered the wire had slipped behind a guide wheel at the bottom of the door. That was put on track with an additional attempt to tighten it. We could still flip the wire out of place with our fingers, but we couldn't imagine what would make it do it on its own...no slamming of the door would seem to be the culprit. Anyway, it works for now, and I got a good lesson in how to remove the door if it does it again. If there is another plastic sleeve that is supposed to guide the cable, we couldn't find it or figure out where it would have been located or how it could have been fitted. I now have two regulator sleeves for the future when the current ones fail. Thanks for all the input guys! Don
