Re: all interior lights dont work
does anyone have a pic of what one looks like?
this thing?
ZMan actually shorted one of these out while installing LEDs under his dash. Had most of the same symptoms. I'll see if he can provide more info. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
I believe, but am not completely sure, that that's one of the modules that's moved between the single and dual airbag cars. Which is yours again, Gamesy?
The 1992 and 1997 diagrams show it in exactly the same place.
ZMan's was a 1995 I believe. Red with beige interior and dual airbags. .
The chime module thingy must be what was in a different spot then.
now here's the question, whos got an extra one? :P
Hi, I did change mine out as John said.
It was behind the glove box on mine, bolted to a metal brace. The biggest pain is removing the glove box. It was a 1995 model. |
You don't?
![]() I've got quite a few, but they're tucked away in a container that's not easy to get to right now. |
Anyone remember what it's shaped like, how many plugs on it, etc? I should have one in a box with a bunch of other random modules. I'll have to look later tonight.
I had to replace mine in my 95. My car did some pretty crazy stuff when it went bad. Mine shorted out because the left front tire kicked something up and cut through the wire harness that goes over the wheel well to the fuse box under the hood.
#28
^ Woah.
Gamesy I looked but couldn't find the time control unit in my big box-o-modules.
#29
getting one from nate, thx anyways
#30
fixed my car without the timing unit.
apparently all that stuff shares the same fuse as the CLOCK fuse in the engine bay when i first looked at it, it looked intact, but i was going through everything today and it was completely obliterated.
