Old 10-03-2011, 12:07 AM
Re: alternator wires
The mega fuses/holders are available at amazon.com. I ordered stuff to do my alternator wiring/battery relocation to trunk mod in a few weeks.
I'm too impatient to wait that long...
Old 10-03-2011, 12:13 AM
Gamesy's Avatar
Gamesy Gamesy is offline
call your local auto parts supplier and see if they can order it, thats what i did, took 2 days and order an extra fuse in case a)one's a dud b) you blow it on the road
Old 10-03-2011, 12:30 AM
Yes, hence the "few weeks" till I'll be doing mine. But I'm not exactly in a hurry, got plenty of other projects going on. Anyway, I meant that more for future reference than right now.
Old 10-03-2011, 01:11 PM
Uncamitzi's Avatar
Uncamitzi Uncamitzi is offline
Member #447
Send a message via MSN to Uncamitzi Send a message via Yahoo to Uncamitzi Send a message via Skype™ to Uncamitzi
More than a little frustrated..
Followed the instructions for the wire upgrade..... buttoned it up... and I get :
Battery light, Steering, ABS, Stoplamp.... sigh.... I think I screwed up a splice......
Voltage to the battery is good.... all the fuses have power... I'm stumped
Mitch Hansen
"uncamitzi"
This is a Dark Ride
92 Teal SVX LS-L 128K tranny swap with 4.11's
Well.. my days of not taking you seriously have certainly come to a middle .
Old 10-03-2011, 01:15 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Check the small wires going to the plug on the alt.
Old 10-03-2011, 01:26 PM
Uncamitzi's Avatar
Member #447
The plug is brittle and one of the wires that I spliced did come lose... but I have to be off to work... I'll check it tomorrow... also...anyone know if there are replacement plugs for the alternator?
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 10-03-2011, 01:27 PM
Gamesy's Avatar
what are those wires in the plug for?
Old 10-03-2011, 01:47 PM
My original source used to be Northwest Regulator Supply. They only deal with manufacturers now.
But you can buy them directly from their distributor Electric Motor Service in Logan, WV. Their phone number is 800- 697-6070
The part number is 050-012252 and they go for $9.53 each plus shipping with no minimum. I already ordered two more.
Old 10-03-2011, 02:05 PM
On the plastic connector, one wire is the field sense wire, that energizes the alternator when the ignition is on. Also monitors battery voltage and uses the regulator to supply additional voltage on demand
The other wire goes to the idiot light on the dash, turning it off when the alternator is charging.
If you are replacing the plug, make sure to keep the wires from getting switched around. Remove only one wire at a time and reconnect to the new plug to avoid confusion..
The original OEM plug has two wires of different thicknesses, the replacement plug has both wires the same size. Mark them however you want when changing them.
Old 10-03-2011, 02:52 PM
svx1999 svx1999 is offline
no but it's mine and I'm pictured.. terrible side shot. I have since took off the upgrade, since it blew an alternator or it's the only explanation. well perhaps a bad one from the shop. I left the negative ground in place.. now It's time to GET another alternator.. I still have my OEM core.. Yes I want it for a rebuild. got the other from Napa lifetime replacement and I think it's an HO.. not the 160 that I'd like to put.. perhaps I need to re investigate these wiring upgrades, from earth grounds, battery, alternator and so forth. As I do have a few things I wanna add.. HIDs for one.. and perhaps a sound upgrade.. I dunno need to find the wires or order.. I remember long ago Beave saying there needed to be an In Line fuse.. Glad it got included.
Happy driving to all.
svx1999
Zeppelin; "Dude, This is not your car!"
John;"I like soup!"
John Hoffman;Date of Birth:
August 11th, 1844
167
Old 10-03-2011, 07:37 PM
Uncamitzi's Avatar
Member #447
I'm betting that the shipping for one will be more than 9.53....
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 10-04-2011, 04:29 PM
Uncamitzi's Avatar
Member #447
Ok...wiring is done...and working...interesting side note..... for the past 3 years I've had to push the sunroof to start it when I wanted it opened...today..after all the wiring to the alternator was redone..... I just pressed the button and it opened by itself....whodathought?
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 10-04-2011, 04:51 PM
Ok... wiring is done... and working.
Interesting side note..... for the past 3 years I've had to push the sunroof to start it when I wanted it opened... today,after all the wiring to the alternator was redone, I just pressed the button and it opened by itself.
whodathought?
i have found that the wiring mod can increase battery voltage by almost 2 volts.
in the case of your tired sunroof motor, that may be all it needed to bring it back to proper health.
Glad everything is back to normal. in the world of gremlins, the electrical ones have got to be the worst!
Old 10-04-2011, 05:46 PM
Uncamitzi's Avatar
Member #447
I still have the code 34 EGR solenoid to hash out... but somehow.... that doesn't seem as important now that I'm not stalling out from a standing start.
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 10-06-2011, 12:23 PM
Uncamitzi's Avatar
Member #447
OK.... raining and cold here...went for a longish drive 30 miles, parked, and on the way back it's almost like my car rebooted... ABS light came on...clock reset... I'm thinking I have a short on the alternator wire I've just replaced.... any other ideas?
Mitch Hansen
"uncamitzi"
This is a Dark Ride
