Old 10-01-2011, 11:23 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Re: alternator wires
Well, my battery was dead. So I jumped it. At first the alternator didn't wanna charge and was like "EH..fook off." then after I kept revving it to get it going, it was like "Ok Ok..I see the new wires" and is charging fine.
Old 10-01-2011, 11:30 PM
Yes, most likely the battery being displeased with a couple months of no use. If I were you I would have swapped back and forth with the battery in another car every week or so to keep it strong. Actually I did exactly that when my blue car was down for the engine swap. Florida is not very kind to batteries.
Old 10-01-2011, 11:45 PM
Glad to hear it is working fine.
I have only started and driven my car once since I got back from Reading.
I always keep the battery connected to the Battery Tender when not in use. One of the best investments I ever made; just unplug and go with no surprises.
Old 10-02-2011, 12:34 AM
Chuckls's Avatar
Designated Asshole
I ended up messing up and not using the KnuKonceptz power terminals or w/e..so I could only do one ground. Gotta order some more ring terminals and I can get it set.
SVXcess, how did you use the bolt for that engine ground? it's WAY too big to fit the ring terminal around.
Old 10-02-2011, 02:26 PM
Gamesy's Avatar
Gamesy Gamesy is offline
eveything cleaned up and running, good thing i bought 2 fuses, 1 was a dud,
and SVXcess i have plenty of room to change the fuse without having to take out the battery, nor did i have to drill any holes, i used the old mounting points for the 4EAT resistor.
Old 10-02-2011, 02:32 PM
Where's a good place to source the mega fuse holder and fuses?
Old 10-02-2011, 02:43 PM
Chuckls's Avatar
Designated Asshole
http://www.littelfuse.com/searchresu...e&Ntt=Megafuse
Old 10-02-2011, 03:01 PM
Thank you, sir
Old 10-02-2011, 03:17 PM
Chuckls's Avatar
Designated Asshole
No problem fine gentleman. Happy to be of assistance.
Old 10-02-2011, 05:50 PM
92 SVX 92 SVX is offline
ok how do you order the fuse? I looked over that link and I did not find a way to order one.
Old 10-02-2011, 06:11 PM
Available at All Battery Sales and Service
Mega Fuse Holder
Mega Fuses
Old 10-02-2011, 06:19 PM
thank you, that is exactly what I was looking for.
I ordered the wiring, and ring terminals I got 6 feet of 4gauge, I figure if 5 is enough I will have an extra foot for other projects. I really like the pricing they have.
Old 10-02-2011, 06:36 PM
Originally Posted by Gamesy View Post
everything cleaned up and running, good thing I bought 2 fuses, 1 was a dud.
and svxcess i have plenty of room to change the fuse without having to take out the battery, nor did I have to drill any holes, I used the old mounting points for the 4EAT resistor.
Take photos please.
Old 10-02-2011, 10:52 PM
The mega fuses/holders are available at amazon.com. I ordered stuff to do my alternator wiring/battery relocation to trunk mod in a few weeks.
Old 10-02-2011, 11:39 PM
Chuckls's Avatar
Designated Asshole
Ok so...I'm sort of afraid..the wire loom I used is NOT heat resistant
and..it looks like my charging post is starting to look like my old one..but I figured that would be caused by my loose terminal..hopefully
