Re: Transmission options
Well finding Gear ratio's isn't hard. and calculating ratios and speed isn't hard either... SO. I guess i need that Dyno for the Stage 1.
SVXT6 (Pearly) just got running 201,000 (body) 105,000 (engine) Honda FT500 Ascot [Red] |
EDIT: I'm sick but now you made me go and think. It occured to me that there may have been an assumption I was missing and now I may see the logic behind this claim that peak torque and peak efficiency occur at the same RPMs. Here goes: Power = Torque * 2 * PI * RPM Assumption: Rate of air and fuel consumption at a given throttle position is proportional to RPM or Fuel Consumption Rate = constant * RPM. Let's call that FCR. Power is energy used per unit of time and fuel consumption rate is fuel used per unit of time. Efficiency would be energy obtained for a given amount of fuel so efficiency would be power divided by fuel consumption rate or Efficiency = Power / FCR = (Torque * 2 * PI * RPM)/(Constant * RPM) = Torque * 2 * PI / Constant So efficiency should be torque multiplied by a constant and should peak when the torque peaks. This has a big assumptin built into it but maybe it makes sense.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 08-30-2011 at 11:54 AM. |
now you got me all thinking mathy and such.
I'm tempted to say there is a "double Peak" in the fuel efficiency of an engine. One where the engine speed is slow enough to counteract the extra use of fuel to keep it at said speed; and another where the engine is "officially" at peak torque, but is detrimented by the higher speed, and therefore more fuel consumption per length of time than a slower engine speed.
I was once told that the most efficient motor would be a 1 cylinder motor running wide open.
older working engines didn't have butterflys in the carburetors... they just loaded the engine down to keep speeds down.....
Some two years later I came across this interesting little article:
http://www.viragotech.com/fixit/Fuel...encyPower.html So, at full throttle, max efficiency does indeed occur at the peak of the torque curve. However, most cars are not running at WOT at cruising speeds so that is no longer the case. To a point, lower RPMs is more efficient at cruising speeds as the parasitic losses are lower and throttle is higher due to the lower HP at low RPMs. The key to fuel efficiency is to get the peak torque down to low RPMs. Because of the lower HP at the lower RPMs, the throttle will be higher AND you will also be closer to the peak of the torque curve. Variable valve timing and other design innovations have pushed cars in this direction. The new 2.0L turbo in the 2014 Forester results in great gas mileage for a car with 250HP because the torque peak is at 2000 RPMs! Just thought people would find that interesting. Assuming the engine doesn't have issues (head gaskets or other), Subaru may have a winner here.
Reason Diesel engines do so good . A ton of torque at low RPM
