Old 08-09-2011, 10:27 PM
Red94Svx Red94Svx is offline
Re: 11:1 Engine Rebuild
This is just a question maybe a little off topic
Why would you want to increase the compressions ratio? Isn't 10:1 high already? Cause most turbo cars have low compression ratio
Old 08-10-2011, 10:08 AM
92 SVX 92 SVX is offline
Most turbo cars have low compression because after adding in the forced induction the compression is substantially higher
If you run Naturally Aspirated higher compression results in improved performance and an immediate kick as soon as you touch the throttle, no delay while the turbo spools up.
Old 08-10-2011, 04:17 PM
dragoontwo dragoontwo is offline
Depending on who you talk to, 10:1 and 11:1 is not considered High compression. I'm not talking about race cars or special applications here, either. When you add in the dynamic compression of any supercharged car, you can easily break 15:1.
'92 SVX LS Pearl White - 6mt
Old 08-17-2011, 09:52 AM
subarvair subarvair is offline
Cam,
I am using a NA EG33 in a project and just starting on the engine here in Tacoma. Would like to get in contact to get more info and advise on your build. PM me if you are interested. Your inbox is full.
Thanks
Mike
Old 08-17-2011, 10:03 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally Posted by subarvair View Post
Cam,
Thanks
Mike
Let me guess, you're putting a EG33 in a Corvair?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-17-2011, 12:13 PM
Bill,
You're right. How'd you guess?lol
It's mated up to a 5 sp TA(not Subaru) and mid mounted. Have pretty much finished the rear suspension/engine cage and now need to tune up the engine. Looking for 225whp NA. Any suggestions?
Mike
Old 08-17-2011, 12:56 PM
Cam Cam is offline
I am cleaning out my inbox as we speak. What are your ideas for engine management? I am willing to help in anyway I can. I could even come down and meet up with you for some face to face time, since I am interested in seeing your project. A corvair huh? Sounds pretty sweet.
Go ahead and PM me and let me know of any questions or guidance you have/need.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 09-03-2011, 03:23 PM
SVXRide's Avatar
Bill,
Mike
Mike,
Hydro engine management, INT/EX cams, tuned exhaust manifolds, minor port and polish of heads, larger injectors.
-Bill
