Old 06-07-2011, 02:51 PM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
Re: Post engine swap troubles
was this white svx the one i sold you and you crashed !!!!!!
i really miss that car !!!
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 06-07-2011, 03:54 PM
Yea this is the engine from that car. I really miss it too James. How's the Evo?
Old 06-07-2011, 08:55 PM
92 SVX 92 SVX is offline
They have a tester that will tell if exhaust gas is in the water, and if there is oil it should be very evident.
the tester I have heard called different things block leak detector an combustion leak detector.
http://www.arrowheadradiator.com/hea..._leak_test.htm
As much oil as your looking at I am thinking valve stem seals are not the problem, You said this has new cams in right? could there be a valve that isnt closing all the way?
