cold weather break problems
Hi this is my first post here on the network so bare with me and my spelling.
My problem is this i live in minnesota and i noticed when the weather drops below 0 or negive -10. I cold start my car it is like really hard to press in the break pedal. i have to use all my weight to get my car to stop. the best way to decribe this is it is like not having power steering but in the break pedal this is really dangerous because my car wants to go forward when i put it in drive. But once my car warms up the problem goes away. also in cold weather my window tend to frost alot on the inside witch is annoying as well. feeback would be much apprehated like to get this done in the summer and not this winter. |
Re: cold weather break problems
First thing I would do is flush all old brake fluid out with new, as it's possible you have a bit of water in the lines, freezing at night. Start by sucking all old fluid from the master cylinder (I use an old turkey baster) and refilling with fresh fluid, then bleed each corner until nice fresh fluid shows up in bleed hose. I'm sure others will chime in with their suggestions.
As far as the inside windows freezing, is it possible you have some water on the floor, under carpets, etc? Also check the spare tire well under the trunk floor for water. Lots of folks have had problems with leakage finding it's way in via tail light gaskets or missing/misrouted sunroof drains. Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket Last edited by RojoRocket; 05-22-2011 at 08:32 AM. |
Might be the formulation of your brake pads thats making them useless at low temps. The EVO8 I had was kinda dangerous in 32degree temps as the tires and brakepads were more like blocks of wood than engineered friction devices. Which makes sense given a design goal for proper operation at high temps during agressive driving.
So if you don't know what kinds of pads are on it, might pay to start researching for some cold weather pads Also you need to check your brake booster and its lines. Water/sealing issues can make for a hard pedal. |
I've experienced this issue. The brake pedal doesn't move when pressed. It's not the pads. Bleeding the lines is your best bet.
flush in dot 4, it boils hotter than dot 3, dot 5 doesn't work with abs
bleeding the breaks with dot 4 sintentic would probable would do the trick, what is best and easyiest procedure to blead the break or to drain the master clinder, break boost would that be the culprit.
http://www.subaru-svx.net/forum/showthread.php?t=56626 Should answer your questions.
1992 (JDM) CXD Ebony Pearl 90K km written off hail damage 1996 (CDN) Lsi, Polo Green, 296,000 km 2009 Legacy Spec B |
Cold weather break.
it's not the best way but the easiest way to bleed in new fluid is to gravity bleed it. turn a bottle of brake fluid up side down on top of your reservoir or just watch it and keep filling it up. crack open the bleeder at each wheel and let it drip out a small hose into a water bottle until it runs clear.
Glenn
you probably want to let it drip for a good 5 minutes, less time in the front but the rears will drip really slow.
