Antenna
Does anyone know if it is there is a replacement for the stock antenna that is not another antenna. Meaning is there an aftermarket receiver type part that you would see on the roof of a present day car? If anybody has any ideas throw them out.
Kind of like this
Re: Antenna
hope this isn't hijacking but mine snapped clean off...it looks like crap to have a little bit of metal left. Instructions on how to remove it entirely?
Re: Antenna
There are instructions in the How-To-Documents section. That's where i had the idea
Re: Antenna
I have a replacement antenna/motor in good shape; if you want it, PM me. Back to the original thread: You can use another antenna but I don't think any that stick on the roof will look right. All you would have to do is run an antenna cable up to wherever you put it and make a hole in the roof for it to pass through. If I were going to shave the antenna, I'd put an antenna inside the trunk lid, where it's out of sight, but should get alright reception since the trunk is fiberglass.
Re: Antenna
I think he meant he would like to put one in the oem spot that is like the modern day ones you see on the roof of cars today. Also wondering if any factory ones from other cars will work?
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
Re: Antenna
Re: Antenna
Some normal antennas from factory cars would probably work, but I can't think of a way to make them work or look better than stock.
Re: Antenna
yeah, i was wondering if you could use the roof ones over the oem spot ya know? i feel like it would look so much cleaner than the metal rod. plus you don't have to worry about a motor on those breaking.
Re: Antenna
The picture you showed is for sat. radio like XM etc. The SVX has two antennas that uses whichever one has the best signal. the 2nd one is part of the rear window defogger and antenna. Of course the antenna in the rear fender will likely pick up the best signal. Take care, BOBB
Re: Antenna
My yellow has no antenna in the rear quarter panel. That hole has been sealed. The radio still works fine, maybe as not clear/stereo as my Teal which still has the stock antenna(up and down).
Imo, this antenna makes our cars look old, modern cars do not have this kind of antenna anymore. If I ever try to take pics for my Teal, the radio will always be off.
Re: Antenna
Re: Antenna
Oh they'll still work but not really well depending on where you live. I live in the mountains so I doubt I'd get as good signal than I would with an antenna. Luckily for me, I hate local radio and listen to Pandora instead.
I am really interested in what one of the more modern ones would look like covering that hole where ours are though.
Re: Antenna
Why not put it on the roof? I think that would look good on a SVX.
Re: Antenna
(Again, just my opinion)
Re: Antenna
yeah, it still works. Not too much problems in my area.
