#46
Re: Confirm my problem is Alternator related
I cannot stress the merits of the Mega-Fuse too much. Read the following article to get a better understanding. Nothing else even comes close for reliable performance and protection. http://www.littelfuse.com/data/en/Te...s/TB98-003.pdf .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
#47
When I'd called to add the wiring upgrade to my order I was informed that the parts would have to be sent two days after the alternator. When she said Friday, I assumed that they still hadn't been shipped yet. By this point I was running on impulse, not believing a word I'm being told by anyone. I thought April Fools was coming back for a second pass. So I did cancel my wiring order with Maniac. I harbor no bad feelings toward them nor you for the recommendation. I look forward to many years of use with my new alternator. Despite having two weeks to fix my car I was running out of options for getting to work the next day (today). I even phoned Enterprise about renting a car for the day. The costs were adding up. I went home empty handed but for the supplies I'd accrued over the previous week. I removed the alternator again (getting pretty good at that one), and gave the knock sensor a good cleaning. I also extended the leads to the alt connector and spliced the replacement in with the pigtail supplied. The wiring from the charging post remains stock along with the battery grounds. I buttoned it all up as the sun went down, finishing the last of it by porch light, and fired it up. She runs. The idle is still bouncing at times, but there is no check engine light. I was able to get to work and back today, stalling only once at my first stoplight about 4 miles in this morning. I'm beginning to suspect that the idle issue may not be related at all, it is a 215K car after all. The driver's front CV joint went bad while sitting too somehow, it didn't even click before. I guess this car just needs to be driven regularly. I really do appreciate your recommendations, and your patience in re-explaining everything to me. I'm goin' it alone on this and it's tough, even with the help of the forum. I still intend to follow up with a full wiring upgrade, using the parts you've called out and the help of my wiring guru, but if this setup is satisfactory then I will continue to use it for my commute. Work isn't a constant thing for me, so it is imperative that I'm reliable when I am called in. I know everyone's thinking, "well maybe an SVX isn't the right car for you" but that's a load. This is an alternator replacement; it shouldn't take two weeks, right? ![]()
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner ![]() Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor Buying parts is like car payments. Someday she'll be all mine. |
