Help with rear wing removal.
Hello all,
My car is almost back together and I need to move on to addressing the cosmetics. I just finished the 3M headlight polish and all I can say is HOLY CRAP!!! They look almost new... I hope they hold up! My next item is going to be repainting the rear wing. My wing has lost most of it's paint and it down to fiberglass on one spot. I figured the best bet was to simply remove the wing from the car to prep it and take it to a shop to have it sprayed. Are there any tricks to removing the wing? To be honest, I have not even lifted the trunk lid to check yet, but I'm assuming there are just a few bolts holding it on, right? If not, can I get some pointers? Similarly, are there any pointers on removing the flaking paint from fiberglass? Thanks in advance. Clarke |
Re: Help with rear wing removal.
When you look under the trunk lid, you will see 4 bolts and nuts. Take off the nuts and the spoiler will come off. As far as removing the paint, sand paper is the only way I have done it. Good luck.
Thanks, I'll get to work on it this weekend.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Do not forget to fill the holes with something like a gasket maker, unless it's going to stay garaged until you put the wing back on. Otherwise, you'll wind up with a fish tank in your trunk ![]() ![]()
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
