Old 03-22-2011, 05:47 AM
peace-frog peace-frog is offline
92 temp guage almost to the red
Just noticed on the way to work that my temp guage goes almost to the red. Wil go down the faster I go but at around 30 mph it just keeps going up. Thermostat was changed about a year ago. Any ideas what might be making this happen?
Old 03-22-2011, 06:24 AM
Huskymaniac's Avatar
Uses the ignore feature
Re: 92 temp guage almost to the red
Check in order of simplicty:
1. Radiator cap (most likely the coolant would be boiling over)
2. Thermostat
3. Water pump
4. Everyone else's first suggestion
Tony
Old 03-22-2011, 06:33 AM
2. Thermostat
3. Water pump
IB headgasket failure.
Huskymaniac's suggestions in this case are the most sensible way to go about diagnosing and curing your overheating problem in this case.
Old 03-22-2011, 07:36 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Subaru thermostat or aftermarket? I had an aftermarket over that only lasted me a year.
Old 03-22-2011, 02:37 PM
coolant cap looks new
thermostat and water pump have around 2000 miles on them
also are there any other ways to tell if it is the head gasket?
on the way home it was similar to this mourning crept up at partial throttle not as high as the red mark. really hoping its not a head gasket this is my daily and im sure thats not a one day job
Old 03-22-2011, 03:15 PM
Freeman's Avatar
Unregistered User
I was almost sure mine was the hg but I had the thermostat and the rad replaced and that seemed to alleviate the problem for now..
Old 03-22-2011, 03:51 PM
well just for good measure im going to replace the thermostat and have my shop clean out the whole system to make sure there is no gunk or build up in there
Old 03-22-2011, 04:41 PM
Are the rad fans coming on? If it's overheating at slow speeds but cooling alright at high speeds that indicates a radiator airflow issue to me.
Old 03-22-2011, 05:31 PM
Blacky Blacky is online now
My sentiments exactly. There's one in the underhood fuse box marked AC that could be the culprit.
Old 03-22-2011, 06:19 PM
I don't know how I did not think of that lol. What's the best way with out driving the car around
Old 03-22-2011, 06:25 PM
oab_au oab_au is offline
Turn the ign on, turn the AC on, the fans should start.
One Arm Bloke.
Tell it like it is!
Old 03-22-2011, 06:42 PM
Thatnks will try it now sorry I sound like a idiot with cars right now just having a off day
Old 03-23-2011, 03:36 PM
did the tests and the fans were not running i switched all of the relays and fuses and tried again and still nothing. so i decided to take them all out and put them back in again and make sure all of the connections were tight drove the car home temp gauge went to normal and stayed there wasn't sure if it was due to the weather that it didn't overheat since it is 26 right now so i popped the hood when i was home and saw the fans running so hopefully everything will be fine now thank you for all the help
Old 03-23-2011, 03:47 PM
If the fans are running you should be good to go. A car will overheat at pretty much any temperature if the cooling system is faulty.
Old 03-23-2011, 03:54 PM
thats what i was hoping for but now i went out side and tried the fan test with turning the ac on on and they did not turn on so maybe the fans were running the whole time ill have to go for a drive later to pick up my new grille and hopefully it will all be good
