#346
Re: Wheels that fit the SVX
define fully functional? airbag, no
#347
Yeah, an air bag would be part of fully functional. Too bad, I almost got excited at the prospect of a MOMO steering wheel!
#348
Hey guys.
I want to buy some new wheels for my svx. I have found some NISMO LMGT4 18x8.5 front 18x9.5 rear rims. Will they fit on the svx without problems? Thank You! |
#349
Staggered wheels will cause your AWD system problems (read: damage), and will probably rub in the rear without rolling the fenders; they do not work well on these cars.
Less of an issue if you have a Front Wheel Drive model, in which case, sorry to hear that. Those wheels are pretty hot though.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
#350
Staggered width, that is...
Staggered offset (which looks the same) is just fine on these cars.
'92 Pearl White LS-L Touring SOLD 4.44 Swap, trans cooler, trans filter, trans temp gauge Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines Raxles front axles |
#351
ok,
thank you guys! greetings |
#352
with 18s the best tires size is 225-40-18
and really, anything larger then 7.5 or 8" wide is really overkill and not needed.. unless you like the stretched tire look on your car and really, dont want the tires to work like they should
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
#353
we have several pics of svxs with a variety of wheels
actually on the cars... most are 18s ..some 17s too I think. planetsvx.com
#354
Rota makes a knock off in various sizes and offsets.
2010 Subaru WRX 1992 SVX LS-L 89k miles-SOLD! KTM 250sx MX bike aka "Killer Pumpkin" |
#355
09 GR STi pre production wheels:
18 x8.5 +55 245 40 r18 dunlop tyres. interestingly silver centre caps, not the sti caps the production wheels came with . also silver, not shaddow chrome. thanks, Ben. |
#356
Could you also make a picture of the side and rear view!!!! Thanks in advance.... |
#357
I found some Honda s2000 wheels for $260 dollars on craigslist and I was wondering if they would fit the svx. They are 5 lug which is odd for a Honda. And from what I have researched and they seem to be 17" and have a 5x114.7 bolt pattern.
1992 Subaru SVX LS-L Pearlie 1989 Mazda RX7 2005 Mini Cooper S |
#358
they should be 5x114.3 and yes the s2000 should have the same bolt pattern but I do not know the offset.
#359
thats too much $ for those..
they have little to no value and low demand rims.. most S2000s had staggered wheels, 7s and 8s from the factory...Not needed on the svx. Unless you want to find another set and make all 4 the same and sell off the extra set. Offset is fine.. hub center I think is the same size, it may be smaller.
#360
Ok thanks a million, I guess I will continue my on-going quest for the perfect wheels!
