Old 12-29-2008, 01:23 AM
GreenMarine's Avatar
GreenMarine GreenMarine is offline
From POST-***** to LURKER
285whp??... Haha, it's back - with 320whp!!
Well here I am, sitting at the computer late at night because I can't sleep... I figure I'll surf NASIOC's "Prooven Power Bragging" forum since I no longer own the SVX and like the feeling of a ~450wtq STi engine...
All of the sudden I see this thread...
http://forums.nasioc.com/forums/show....php?t=1652516
With THIS Video in it...
http://www.youtube.com/watch?v=wqnuj58lFQI
That's right... That 3.3ltr (EG33) swapped race 2.5RS is back... This time with a fully build motor, and the results (AND VIDEO) are mind-blowing... I mean I can't imagine an SVX with this much NA power. That's almost as much that's in my current car!!
I'll tell ya what though, seeing this thread really REALLY makes me miss the SVX and all the dreams I had for it once apon a time ... I hope I can find another SVX someday...
~ Chris
2020 Subaru Outback Touring - Wife's first Subaru
2005 Volvo V70R - 5-cylinder love! :Heart:
** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned
** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!!
** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love...
Old 12-29-2008, 01:58 AM
Twinboosted's Avatar
Twinboosted Twinboosted is offline
Nissan guy
Re: 285whp??... Haha, it's back - with 320whp!!
Nice numbers!
What's up with the dyno pull though? Does the shop not know how to do a pull correctly?
______________________________________________
1990 Nissan 300ZX TT
Old 12-29-2008, 09:00 AM
This is really old news... Has that imprezza gotten into your head and slowed you down??
Old 12-29-2008, 10:38 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Originally Posted by Twinboosted View Post
Nice numbers!
That video is of a top-speed run, not the actual dyno pull. With the Mustang dyno you can insert the car's drag coefficient from the database, the vehicle's weight and gearing, and then do a 'pull' with simulated drag from the dyno. 7600 rpm's in 5th gear on that run according to Jack.
Bob Légère
EG33 Impreza tweaks
Old 12-29-2008, 05:51 PM
BOB! You're "Bob the Fabricator" aren't ya?? I've gotta meet you if I come up to CT sometime!! Someday I will have another SVX and I really REALLY want to do a nice NA build on it...
~ Chris
Old 01-16-2011, 06:08 PM
RallyBob's Avatar
Just an FYI. The car this engine is fitted to is being parted out, therefore the 318 whp/276 wtq EG33 (now 3.5 litres) is available as a complete engine with oil pan, headers, cold air box. (ECU is separate however)
Interested parties should contact Jack Laverty at EFI Logics.
Bob Légère
EG33 Impreza tweaks
Old 01-16-2011, 06:48 PM
Huskymaniac's Avatar
Uses the ignore feature
Any idea what they are asking for it?
Tony
Old 01-16-2011, 07:07 PM
RallyBob's Avatar
Like I said, contact Jack for specifics. I *think* he was talking around $5k however.
There's about $10k in parts and machine work invested. That does not include the R & D me and Jack invested nor my labor to port the heads, flow the heads and design the cams, build the headers/collectors, and build the cold air box. So realistically there's $13-14k invested in it assuming my time is worth $50 per hour.
Bob Légère
EG33 Impreza tweaks
Old 01-16-2011, 09:23 PM
Is this engine in Bethel? I wish I knew when I was in CT for XMAS. I would love to have seen it in person. Any idea if there was even an issue with cooling? There was a long thread here about cooling issues at high RPMs. I assume an engine like this in an SVX would require a highly customized radiator setup.
About the numbers, the stock engine produces 230HP and it sounded from the thread linked here that this engine produced somewhere above 390HP with 318HP being delivered to the wheels. Is that correct?
Tony
Old 01-16-2011, 09:41 PM
Cam Cam is offline
Bob, any Idea what it would cost to duplicate that oil pan? Did you guys use OEM windage baffle and sump?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 01-16-2011, 09:51 PM
+1 another interest.
Old 01-17-2011, 08:18 AM
RallyBob's Avatar
No, the entire car is at Jack's house now in northeastern CT. He's sick of dumping money into it and now that he's married the wife frowns upon a $20k per year racing budget... So he decided to part it out.
The cooling system was working well the last time he had the car out. 8200 rpm shift points and all. An SVX would have far more room for a bigger radiator as well as more space for proper airflow compared to an Impreza.
It made 318 hp to the wheels on a Mustang chassis dyno. Call it 415-420 hp at the crank (24% driveline loss).
I think that if someone invested in ITBs with this combo you'd see another 30-40 whp.
Bob Légère
EG33 Impreza tweaks
Old 01-17-2011, 08:25 AM
RallyBob's Avatar
Not much in material, but it took me about ten hours to fabricate it. I suspect if I did another one it would take a little less time because I templated everything.
However I built the oil pan on an spare block with the headers present and with the crossmember available to me (Impreza). I don't know if it would clear anyone else's exhaust system and the SVX crossmember.
I did retain the stock oil pan baffles, and the stock pickup tube.
I had some issues with the original sump tube arrangement, and ideally I wanted to create a new sump location...but time/money was an issue so I compromised and kept it OEM for Jack's sake. My next EG33 oil pan will be a dry sump design however....
Bob Légère
EG33 Impreza tweaks
Old 01-18-2011, 01:36 PM
Dessertrunner's Avatar
Is he going to sell the ECU with the engine? Also you say contact him direct how do we do that?
Tony
Old 01-18-2011, 06:45 PM
RallyBob's Avatar
Apparently not, the Motec tuner/distributor would like to buy the ECU back from him.
Tony
Jack works here.
Bob Légère
EG33 Impreza tweaks
