eg33 and megasquirt
I am going an EG33 swap into a 1998 legacy wagon and I am planning on running everything with megasquirt version 2 or possible 3 if I feel like dropping the extra dough. I already have an engine, ecu, and megasquirt harness.
I've been doing a bunch of research at rs25.com but as soon as I asked ECU questions they sent me straight back to you guys. Big this I want to work on is OBDII readiness and possibly CEL functioning. However I am not using any SVX wiring so some of that I might be going alone. Anyways who has any experience at all with any of this and would be willing to help me out? |
Re: eg33 and megasquirt
I know NYS would have a fit if you were backdating an engine on such a "modern" car. If it's the same where you are, I don't know that you stand a chance of getting this swap done to meet spec.
If he is running a stand alone controller could he not piggy back his ecu to meet emissions? |
yeah I sort of need an example on piggy backing, I have a 2.2L ecu now and a 3.3 engine and megasquirt. I feel like I can do what I want with what I have just need to see it done |
I don't think an EJ22 ECU will do much with an EG33...
NH shouldn't worry about backdating, I should be ok
How much does a megasquirt cost? I can't imagine it would be cheaper than just getting a '97 or '96 EG33 ecu. What's your reasoning here?
I already had megasquirt in a drawer
new Hydra Nemesis 2.7 Stage 5 has capability of working with obdII and showing codes.
Unfortunately I know nothing about piggy backing I just read ppl have done that to keep the emissions happy, the stock 2.2 would not do anything to control the engine, the megasquirt would take care of all that then just feed the signals to the 2.2 to fool it into believing all was working.
I hope that's so! It puts a big damper on what we can do. I'll stick to older cars for fun.
I'm not even worried about running emissions right now, can megasquirt run an EG33? I want to know if I have to do something about the crank position and tach signals or do the stock sensors work?
Yes it can. Get in touch with Dynomatt, he has done it on his engine.
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
