Re: manual clutch pedals
Hi guys.
I converted my SVX to manual transmission in 2009. I used a legacy turbo transmission, pedal assembly and a hydraulic clutch system. It works fine, but its not perfect, because the pedals arent in a good position. To prevent trouble with the gas pedal, I installed an adapter between the pedal assembly and the firewall of 1.2inch. Now, I want to make it better, because I cant fill the hole in the firewall and I want the pedals all in one line. The problem is, that when i remove the adapter, I will get problems with the gas pedal, because it will bump on the rod for the clutch. Can someone help me , who did the same conversion and solved this problem? Thanks in advance! PS.: sorry for my bad english, hope you can understand everything fluo |
