Old 01-02-2011, 06:01 PM
Bshade's Avatar
Bshade Bshade is offline
Send a message via AIM to Bshade
What is this device under the intake?
I am removing all the emissions control devices from my H6 that is going in my 91 wagon and found this guy under the intake. I don't know what it is as it looks like an IAC by the way its plumbed but the IAC is on the throttle body. I am just wondering its function so I know if I can remove it. I don't see any wiring for it on my engine control diagrams. Also I don't want to hear any "why are you removing stuff its there for a reason and leave it" I hate emissions equipment and seeing as I am doing this as a swap with a huge harness merge I am not going to also wire all the emissions stuff back in so its gone.
Brad
1988 Firebird Trans AM, 1987 BMW 325is,
1978 Dodge RamCharger, 1989 Chrysler Conquest,(2)
1988 Merkur XR4TI 1973 Super beetle Baja Bug
2006 Chrysler 300C SRT8 1996 Buell S1 Lightning
1998 Subaru Forester 1993 Chevy K2500
Old 01-02-2011, 06:08 PM
Manarius's Avatar
Manarius Manarius is offline
Re: What is this device under the intake?
Those pipes make me think it's something part of the PCV system, which is something I would keep (even though it's emissions related).
-Jason
-Obi Wan Kenobi
Old 01-02-2011, 06:27 PM
dennyo dennyo is offline
Looks like aux. air control valve.
Green1995SVX's Avatar
Subaru says it's the "Auxiliary Air Valve", for what that's worth.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 01-02-2011, 07:17 PM
Bshade's Avatar
Ok auxiliary air valve is going to be gone. as for the PCV I am going to keep that stuff as its keeps the seals from blowing out just a little bit longer. LOL I am actually looking at running an electric air pump as a vacuum pump to the breathers so I don't have to pull the oily air into my intake. that or plumb in a vacuum port in the exhaust.
Thanks so much for the help guys,
Brad
Old 01-02-2011, 07:46 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Somebody, correct me if I'm wrong... That piece might be influential to your cold idle.
Old 01-02-2011, 08:18 PM
From the FSM: Aux. air valve supplies by-pass air only when engine is cool. Also from the FSM: More than half the air for idling is supplied by the bypass valve.That's under the TB.
Old 01-02-2011, 08:41 PM
oab_au oab_au is offline
Yes you do need that one. It does the 'cold start fast idle'.
One Arm Bloke.
Tell it like it is!
Old 01-02-2011, 08:42 PM
Huskymaniac's Avatar
Uses the ignore feature
No, you are not wrong. I think mine got gunked up when my PCV was stuck and it does cause a bouncy idle when cold.
Tony
Old 01-02-2011, 10:19 PM
Bshade's Avatar
The one on my SVX must stick because it sometimes stays at high idle like 3 grand till i shut if off and back on. So your saying I need it just for cold idle right? I will have to look at the ECU pin out again to see if they list it to hook it up.
Brad
Old 01-03-2011, 03:09 PM
Brad
It would be a problem to do a cold start without it. It is wired off the Ignition switch. Just a bi-metal strip that heats up, to turn it off, Bolted to the water manifold to keep it hot.
One Arm Bloke.
Tell it like it is!
Old 01-03-2011, 04:29 PM
Bshade's Avatar
So the 91 wagon I am putting the engine in would not have provisions for that off the old engine either. I am going to unplug the one that is on my SVX and see how it starts tomorrow. If I have to start it like I do my old dodge with the throttle open just a bit thats fine by me. LOL My end goal with this wagon is a rock crawler/mudding car. I am hoping with extensive fender cutting and smashing i can fit 28"
Brad
