Noisy lifters and the magic Honda oil filter.
I have a 99' Acura RL with 145,000 that's doing exactly this:
http://www.justanswer.com/questions/...they-put-mobil I did not put Mobile one in it, but I did start using Fram oil filters around 9K miles ago when the problem started. At first it was just a mild tick, big deal Honda's do that. When I got the thing you could not tell it was running. Now it ticks just like noisy lifters but real loud, almost a knocking. It's pretty bad. Worse than any Honda's usual ticking that I've heard before. It does not get better when the valve train warms up either. So, I'm wondering, is there such a thing as an oil filter check valve that prevents oil from going back into the block? Would that cause engine noise? |
Re: Noisy lifters and the magic Honda oil filter.
I have heard of the check valves before, not sure if the honda one has one or not. Though i would never use a honda filter any more. I think every single one is made by Fram these days.
When was the last time your valve lash was adjusted? also, ditch the fram filter, go with a purolator.
94 Acura Integra GSR 97 Legacy Brighton - EG33 Swap still in progress ![]() 03 Silverado 2500 - Duramax |
+1
Fram filters are about the worst, most problematic filters I have ever used. Read this review of a Fram filter from a 1991 Honda Accord. http://www.dslreports.com/forum/r218...-FILTER-REVIEW .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Yea... come to think of it I've never gotten a car back from a mechanic with a Fram filter on it.
I might try sea-foaming the engine, or taking it to a good Honda mechanic. I've tried 10w30 and 5w30 (which is the recommended viscosity) no change really. Such a nice car.. hopefully the engine does not explode. P.S. From what I understand this car has hydraulic lash adjuster, but they can wear out. Maybe I should take a head cover off. |
^ could be, i don't know much of anything about the honda V6s, pretty much just know lots of useless crap about the I4s...
