Old 10-27-2010, 05:27 PM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Android dyno
I am attempting to setup a dyno program on my evo 4g. I know they arent real reliable or accurate, but I wanted to see how the free dyno app did, and I could post you guys the charts when I'm done. Anyway, I need some help, there are a few pieces of data that the program needs that I just cannot find, please anyone with an idea or even a good guess, chime in!
Pitch characteristics - ? default is 2.00*/G (pitch angle in degrees @ 1 G acceleration)
Roll characteristics - ? default is 2.50*/G (roll angle in degrees @ 1 G cornering)
Weight - my 94 fwd should be 3375lbs according to the interwebs
Drive train losses - ? Whats typical for subies weird fwd trannies? default is 15%
Rolling resistance - ? Need to look at my tire manufacturer? Psi? Weight? default is 0.015%
Drag coefficient - 0.29 cd - interwebs
Frontal area - 0.557 m2 - interwebs
Alright... help!
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 10-28-2010, 03:01 AM
sd2649's Avatar
Driving in Style
Re: Android dyno
Nobody????
-Steven
SOLD
Old 10-28-2010, 04:45 AM
Re: Android dyno
drivetrain loss on the awd auto is about 25-30%
Old 10-28-2010, 08:32 AM
sd2649's Avatar
Driving in Style
Re: Android dyno
Sooo... the fwd would be higher than 15%??
-Steven
SOLD
Old 10-28-2010, 12:51 PM
Re: Android dyno
Yes, the FWD still works very similar. I haven't seen any numbers, but it's still going to be 20-25% on a fwd auto on the SVX, more than likely closer to the 25%
Old 10-29-2010, 02:22 PM
sd2649's Avatar
Driving in Style
Re: Android dyno
Even with the rear diff, center viscous clutchplate for the awd hookup and all those drive shafts/cv axles missing, you think its still close to 25%..... no way, its gotta be a ton lower.
-Steven
SOLD
Old 10-29-2010, 02:47 PM
Oh neat, I just downloaded the same app.
I would put 20% for the FWD auto, but I have no idea.
Old 10-29-2010, 02:55 PM
Banned
Re: Android dyno
look at edmunds etc. they typically have all the stats you need for it, I did the app and tried running it for my speed6 since my svx is still out of commission but i did it when that app first came out and was in beta, glitched like a mofo and never worked. last time i tried to calibrate it wouldn't let me... (garminfone)
Old 10-29-2010, 03:11 PM
sd2649's Avatar
Driving in Style
Re: Android dyno
Is it called adyno?
-Steven
SOLD
Old 10-29-2010, 05:03 PM
Re: Android dyno
The fwd still works in much the same way, input shaft goes to rear of transmission where it meets a reduction gear and has to get transferred all the way back up to the front differential. It's going to be in between 20 and 25%, definitely not lower than 20% since the AWD has been shown to be at around 28-30% on a true dyno...
Old 10-29-2010, 06:14 PM
Cam Cam is offline
Re: Android dyno
I always thought that the parasitic drag from the driveline, rear diff, and rear axles would impact the drivetrain loss a lot more than just 5 percent. closer to 10...can anybody confirm actual numbers?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 10-29-2010, 08:51 PM
sd2649's Avatar
Driving in Style
Re: Android dyno
I cant, lol
-Steven
SOLD
Old 10-31-2010, 08:12 PM
Banned
Re: Android dyno
ya I had adyno, but my phone=suck right now I'm gonna have to go to tmobile and ***** tomorrow I can't even update any apps right now let alone download anything it's having a meltdown.... I'm going to beg for a free galaxy S wish me luck!
Old 12-25-2010, 09:49 PM
sd2649's Avatar
Driving in Style
Re: Android dyno
Any luck with that galaxy s? Anyone else messed with this app?
-Steven
SOLD
Old 12-26-2010, 07:47 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Re: Android dyno
I hear Dynolicious is a good one, but it isn't free, and I don't know if its for anything other than iPhone/iPod Touch.
