Valves
Those who have built their EG33's for FI what valves have you used? has anyone found higher quality valves??
Re: Valves
Supertech sells a set of SS intake and inconel exhaust valves (standard size). They're usually on Ebay.
Re: Valves
is that really the only option out there besides oem?? damn those are pricey!
Re: Valves
I believe when LAN was putting together valve and spring kits along with his camshafts, he was using WRX springs and custom 92 mm valves if my memory is correct. Look through some of the old stuff of his and you can find info... Otherwise when i have time when i get back home next week I'll page through again to find the info...
Re: Valves
TOm |
Re: Valves
hrmmmm ideas.... I must research more
Re: Valves
the ones for the EJ205????
Re: Valves
would supertech wrx valves with wrx buckets be mejor????
Re: Valves
If you are going FI, you'd better budget for the exhaust valves. They should be of superior alloy to withstand excessive heat.
Yeah, the upper portion of the engine is a kick in the nuts...
Re: Valves
tom what all would I need to be able to fit them to the EG33???
Re: Valves
If you opt for +1mm supertech wrx valves (with inconel exhaust) I would be interested in splitting the extra set needed with you.
Re: Valves
Tom |
Re: Valves
do I just need to get them the same length as the normal SVX ones??? or what length would I be looking for?? I'll see if I can get in contact with supertech about getting something set up. I've submitted to CP and Eagle and I'll be talking with them later this week at SEMA so I should have that end set up. I also have cometic set up so I've got most the stuff set up for the engine build.
Re: Valves
Tom |
Re: Valves
If you buy my car, it comes with everything you need. including custom CAMS, valves and valve springs, supercharger kit, STi drivetrain, Custom CP pistons, and egine rods.........
Just say'n..... |
