trans issues
so i have been driving my car a lot lately on the interstate. (brand new certified tranny with mobil 1 fluid in it) It seems like on the interestate when i'm steady at 75 it will slip and then go back into 4th and then overdrive. what would cause this? it doesnt do it around the city at all! i can go 55 and nothing will happen. but around 75 to 85 it will. it seems like its getting confused.
94 Subaru SVX FWD 51k 04 Mazda B4000 (work truck) |
Re: trans issues
My silver SVX used to "gear hunt" badly at a particular speed/RPM range. Replacing the throttle position sensor solved the problem.
dcb |
Re: trans issues
Listen to this man jj. I have found him to be very accurate and helpful!
Re: trans issues
My laguna on occasion does the same thing. |
Re: trans issues
Yes, check the adjustment of the TPS.
When you had the trans installed did you have an external cooler added? If the ATF gets too cool it will unlock the torque converter.
Re: trans issues
i do not have a external cooler installed yet on it. i have one that i'm gna put on it with a filter kit and i'm gna run a gauge. but a tps sensor is 254 bucks at my parts store in my town!
Re: trans issues
Dave - 03 Baja - 92 SVX - 86 Brat - 08 OB 3.0 Last edited by Hocrest; 10-02-2010 at 10:26 AM. |
Re: trans issues
$169.99 + tax/shipping at Autozone's online store.
As others have suggested, try cleaning/adjusting first. My TPS "bad spot" was 50-55 MPH in 4 the gear. 75 strikes me as a bit high for a typical throttle position. dcb |
Re: trans issues
Can you bring it back to whoever "certified" it?
1991 SVX L JDM |
Re: trans issues
Yes the TPS can be a cause of the, torque converter unlocking and locking up again. The vibration of the throttle shaft, causes the TPS wiper to etch the carbon tract, to form a bad spot. This usually is at the throttle position that, the car usually cruises at.
The Overdrive term is just that, to drive over the 1:1 ratio. As Dave says the gearbox gearing is higher/over 1:1, so our 4th is an overdrive ratio, as 3rd gear is 1:1. This really does not mean as much to-day as it did when we had 3 speeds and a add on box, to provide an OD ratio. Now most boxes have 4th gear at an overdrive ratio. Locking the converter, is more about economy than raising the ratio, as it can lock in other gears too. Harvey.
Re: trans issues
so replace the TPS
Re: trans issues
