Subaru debuts 3rd gen Boxer
![]() http://www.autoblog.com/2010/09/23/s...linder-engine/
1992 NZDM SVX Maroonish Red ![]() ![]() 1989 Vortex 6 Maroon 1983 RX Silver Grey 1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration |
Re: Subaru debuts 3rd gen Boxer
I saw an article about the engine several weeks back, chain drive. What is not known, but believed, is that the engine has close bore spacing like the 3.0L. Very interesting, thanks for posting the pic
Special Thanks to Our Friends and Sponsors: * ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Slickness. Now for the bigger bores.
The Worm ![]() _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
Still 2.5L, bore and stroke changes are marginal.
If you want bigger bores, open up an EG33 ![]()
Does "separate cooling circuitry for the block and the head" = no head gasket failure worries?
dcb |
So, it looks to me like there is one big serp belt on that engine. And what the heck is the huge pulley at the bottom near the exhaust?
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Looks like an idler
I bet it is the water pump, and the coolant changes have to do with emissions I would figure. It looks pretty standard as far as what everyone else has going on right now. I don't think it will have head gasket problems, hopefully it will be good about leaking oil, too.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
![]() Perfect place to turn the belt ![]()
externally driven water pump on a subaru? I hope the belt snapping triggers an engine shutdown.
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 09-25-2010 at 07:22 PM. |
You don't want to have a water pump driven inside the timing chain cover. I think only GM is stupid enough to do something like that. It would leak coolant as it aged inside the timing cover and cause coolant in the oil. And the belt won't break if it is replaced regularly. Plus a bunch of lights would come on to let you know it did.
But I'll tell you what today's customer would notice: The a/c wouldn't work anymore. This is a natural progression for them, and I am sure Toyota had a hand in it. I say it is natural because it really just looks like a modernized, scaled down EZ. I like that it has variable timing at each cam, and I bet the 2.5l will be good for close to 200 hp.
i like the looks of this and about time they get rid of the dreaded HG saga once again.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
Even the EA82's and XT6 that had timing belts, used the accessory belt to turn the water pump.
I guess it's been a while since I was under the hood of an EA82. Too many times under the svx hood has warped my memory. ![]()
