Wants to overheat
OK guys, having an issue with my poor little car.
Not quite as bright and shiny as she was 7-8 years ago when i bought her, She has some minor rust starting, a few minor bumps and scrapes (daughter's been driving her), And now she's wanting to overheat... I made sure the radiator has fluid, the oil is good, etc...(just checking everything...) It has an aftermarket radiator of some kind, but I have no way to get any info on it or the hoses or anything, no longer communicating with the guy who did the trans swap, radiator, etc. My best guess is a thermostat? But where is it and how hard is it to get to on this car? Does that sound reasonable to you guys, or do you have other suggestions? Thanks! ~M
'92 Pearl White LS-L Touring SOLD 4.44 Swap, trans cooler, trans filter, trans temp gauge Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines Raxles front axles |
Re: Wants to overheat
A few more specific symptoms please. How does the temperature gauge react? Just climb and stay there or fluctuate up and down? Is there anything you do that causes the gauge to fall? Possible causes are a bad thermostat, a bad radiator cap or the dreaded head gasket. How many miles on the pearlie? .
Whos gonna say it? Im not going to, not this time. |
Over 150Kmi, climbs and stays, just replaced the radiator cap after the first episode of this, just in case...Head gasket?! Ugh, let's hope not.
Thanks! ~M Quote:
That's pretty helpful? What are you on about?
Our head-gasket problems almost seems to be more of a time problem than a miles-thing
Keith |
Ok, do a block test on it, or pay someone to do it. Very easy, quick, and cheap way to find out if you have a HG problem.
Drivers side, Look for the thermostat housing on the bottom of the engine, drivers side The lower radiator hose connects to the housing. The housing is held to the block by 2 10mm bolts. 21200AA072...Thermostat...$12.15 21236AA010...Thermostat Gasket...$2.62 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 09-13-2010 at 08:56 PM. |
Yeah, good luck getting help from that individual. It could be a stuck thermostat but it could also be a dead water pump, no? I can't recall but there is an easy hose test for a thermostat stuck closed and I'm sure svxfiles can give a good test for the water pump. In my case, the gauge temp sender went bad but the reading was low, not high. It is possible that the gauge itself is bad. If you were close I would plug in the code reader as it can capture live data. That would verify that the temp is indeed going high, versus it being a gauge or sender issue. That's how I knew my readings were bogus. Svxfiles gave me typical temp readings and my ECU was reporting normal temps while the gauge was reading off. And, yes, it could be a head gasket. But don't assume the worst and start with the cheapest stuff first. Make sure the gauge is reading correctly. Then move on to tests for the thermostat. Then the water pump, etc.
It was on its way to overheating. Not a bad gauge.
Thanks for the thermostat info, I'll check that. If someone has a test for the water pump, let me know. Here's hoping... ~M
Found this as a test for a stuck closed thermostat:
"If the upper radiator hose is hot at the engine end and cool at the radiator end, coolant is not circulating. The upper hose is normally cooler than the lower hose due to cooling via the radiator." and "Compare the temperatures between these two hoses. Keep in mind that when operating normally, your lower radiator hose should be warmer than the top hose. If one hose is a lot warmer than the other, then it’s highly likely you have a stuck thermostat. " I suppose it is also possible that the radiator is clogged.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by immortal_suby; 09-14-2010 at 02:29 PM. Reason: removed quote |
How long after the car is running does it want to overheat? Also, what kind of driving are you doing when it is happening, city or highway? A/C on? Fans working?
Tom |
Within 10 minutes, maybe sooner. It was in town, slow city driving with the a/c on. Fans sounded like they were working fine.
Start with the thermostat. Cheapest and easiest. You should be able to do it yourself if you have some standard tools. If that doesn't work then I would move on to verifying your radiator is not plugged. If none of the above applies there may be a good chance your headgaskets are on their way out (or if your lucky like huskymaniac was it could be a gauge related issue. He was the exception rather than the rule though).
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
The thing that I find interesting about Michael's case is that the temperature rises quickly and stays high. In most of the HG cases, doesn't it usually start off with the gauge reading normal, spiking randomly and then settling back down? On a related note, I really enjoy seeing the words, "This user is on your Ignore List."
