Old 08-02-2010, 03:14 PM
siceclipse's Avatar
siceclipse siceclipse is offline
Re: Performance Timing Belts
Coming from the DSM backround and currently owning a DSM (racecar) and Evo 8 (daily driver) I would NEVER use a Greddy, HKS, Cosworth, or Gates belt.
All of these (and i might be mistaken) are carbon/kevlar or just kevlar belts that dont promote natural stretching under heat cycles and time in general. In simpler terms they dont stretch a few mm like a normal belt should and will most likely SNAP.
Most of these are RACE belts and when used in this type of application are changed out very often.
On a normal daily driven car I would always go with OEM.
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 08-02-2010, 11:31 PM
Can you show me an example of a low mileage race belt that got snapped on a low mileage application?
For your info, those belts are made of steel lines with are thicker than normal OEM's with rubber/cloth housing same as OEM's but with an added layer of Kevlar on top.
