#316
Re: 11:1 CR Race/Street Engine build
Permacool... its a relatively generic adapter plate...
Tom |
#317
Hmmm there is a sandwich adapter that fits above the filter and is connected to the cooler through the SS hoses.
I would assume it is an Earl's Performance (not our Earl ![]() ![]()
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
#318
Ooops I just saw your reply Tom. I checked Permacool and it seems there are different models, 182, 185, 186, etc... which one fits the EG33? Sorry I don't have the car on hand to take measurements right now
#319
Looks sweet... I hear its good for warming up waffles in the morning as well...
![]() Dual purpose for everything :-D |
#320
I used the 186... The O-rings supplied didn't quite work well for me, so I got a square o-ring from a different filter (one from my shop I work at). Pulled it from the filter, fit it to the adapter plate and used that instead. Just a heads up
Tom |
#321
-Bill
#322
yes they are. I buy all the oil cooler products for my customers cars through Bat inc(www.batinc.net) Mocal and Setrab, nothing else. I've seen cheaper coolers split, and had a friend lose a $70K Stohr Wp1 race car to a horrible oil fire because a cheaper replacement cooler failed(AN fitting split right off the cooler). The cheaper snadwich plates tend to have orings(on both the main seal and the fitting seals) that are already dry rot form the start and just leak like nuts. Also on any NPT fittings that thread into the sandwich plate and/or the cooler, I'll use a little bit of Permatex Hydraulic thread sealant(it's purple) as it locks the fitting into place and seals it permanently without having to cram the fitting down hard. MANY people overtighten these fittings and either split the snadwich plate or stress the cooler and end up with a high pressure oil leak. for subaru you want part number SP1F. thread is 20mm. The thermostatic unit is a very tight fit(SP1FT) and locks you into a small range of hose positioning, but can be used with a 1/2" thick spacer(also avail via batinc) for better positioning. I shoot for about 180F oil temp if considering a thermo unit. if using a full flow sandwich plate i just size the cooler accordingly to acheive that temp. I am running SP1F with cooler #A16A10HD on the Eg33 with lines I made to fit. Last edited by Boxersix; 07-16-2010 at 12:27 PM. |
#323
also NAPA 1357 as well. larger capacity than those dinky stock subaru filter for sure. |
#324
-Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 07-16-2010 at 02:27 PM. |
#325
SP1F is about $70, SP1FT is about $120, and the cooler I mentioned is about $200(all prices + shipping charges). Line is about $14.5 foot(aeroquip, I use nothing else and YES there is a difference between it and cheaper line), fittings range in price. Estimated, the cooler setup on my car is about $430 retail not including that bracket holding the cooler to the motor. Doesn't get much higher quality than it though, say for maybe a Setrab core but that's a bit overkill for a street car. My wholesale prices are a bit cheaper, but I'm not at my shop to look up now unfortunately. |
#326
Starter broke again. Engine doesn't really like to start. Have to coax it. All packed up and ready to go to pocono for the weekend. Tried to start it; hadn't run it for a week or so. Nothing for 2 or 3 times with the starter. Then it almost caught, a couple of cylinders fired; there a clunk, and then, the next time I tried, the starter rotated freely without engaging the flywheel gear "Wheeeee." This is getting tedious. In the old days, the prescription would be a broken bendix spring. $20 and an hour or so of labor. Not any more.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#327
Truth in every way! It would be nice to attempt to may a hybrid starter using a manual starter nose section and the motor section from an EG33 auto, armature rewound for a little more torque ![]() Or just look into modifying a Porsche 911 G50/96(~'90-'94 964, 95-98 993, any GT3 or '01+ 911 Turbo) to fit. The mounting is very similar and those starters turn over 3.8L 11.5:1 GT3 race motors like butter ![]() |
#328
Actually, the starter seems to turn it over pretty quickly. With this high lift longer duration camshaft and other mods, it just doesn't like to start. Even after I get it going, I have to give it a little accelerator for a couple of minutes or it will die. The problem is, I think, that starter turns it over a number of times and then the engine fires a couple of times, and the starter drive gear doesn't get disengaged and the disengagement assembly breaks. I suppose I could have knocked a tooth off the flywheel ring gear and the drive gear is hitting the toothless spot. I should put it in gear and give it a shove to rotate the flywheel to see if that's the problem. Had that problem in a 66 El Camino 283. Sometimes, the flywheel would be in the wrong place and the starter wouldn't engage. Just had to rotate the crankshaft a little bit, and then it was OK.
#329
How is you car tuned?(MAS, MAP, Alpha N) I see Hydra in your sig. |
#330
Hydra. Tom leaned it out a little bit, in my quest to pass emissions. I'm easily passing at 2500, but failed on idle, probably because I had to leave it at the shop and he probably let it sit for a while and the cats cooled off. It failed with very high HC (634 ppm), but a good CO (about 68ppm) and an O2 reading of 2.8%. That tells me the cats weren't working. If they were, and HC was very high, CO would also be high and O2 would be nothing.
Anyway, once it gets warmed up, it runs great. Getting it there is a problem.
