Power Steering fix - Why did this work?
For a while now I’ve had problems with my power steering cutting in and out at low speed when the car is cold. When it was happening I could hear the serpentine belt chirping too. I’ve changed the “o” ring at the power steering pump and adjusted and readjusted the tension on the serpentine belt. I was beginning to think I’d have to change out the idler pulley or maybe the pump itself. I knew it wasn’t the alternator pulley because I’d had to change the alternator when I was having this problem and that didn’t help either.
While I was trying to figure this out a neighbour dropped by for a beer. He suggested I spray the pulley with tire cleaner with the car running. I thought he was nuts – that that would only reduce friction and compound the problem. But it worked! The problem was gone 30 seconds after I sprayed the pulley with a couple of shots of Wet’n’Black tire cleaner. Go figure. I just hope the fix lasts. |
Re: Power Steering fix - Why did this work?
It's an old belt and that stuff softened the rubber?
When was the belt changed last?
The belt is only two years old with less than 15,000 miles on it.
Ooops - wrong car. It was my son's SVX that I changed the serpentine belt a couple of years ago - not mine. My mistake.
The belt in my car came with the car when I bought it in 2004 so it could be quite old. It looks in good shape though. |
Belts can look good but still have rubber that's completely dried out. My friend's Buick was chirping constantly, new supercharger belt solved the problem.
You should have just drank your friends beer and you wouldn't have cared.
![]() ![]() I have had belts screech and make all kinds of noise and they looked fine. When I finally gave up and replace them, the noise went away. The tire stuff may have just waxed the metal so it wouldn't make noise any more. ![]()
![]() This could be tip worthy of the how to section. ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
I will figure out how I can post it there so members will get the benifit of this fix.
Beautiful addition to our how-to...
I frequently ask my wife, is the whole world crazy or is it just me... I would simply pay a few bucks and get a new belt that I could depend on, but I am a coward... afraid I might get out on the road and have the belt break and loss of steering control could even cause someone to be killed... My wife usually says "it is just you" ![]() Keith ![]() |
Of course there is a spray product called "belt dressing" that does the same thing.
Lee
Again...
Belt dressing is not intended for use on planet earth! Keith ![]() |
![]() http://www.canadiandriver.com/forum/...?topic=60345.0 I'll drive it for a while as is and report back. |
![]() She will also tell you that a broken belt is not going to cause a catastrophe and she could cope. When the car is on the move, loss of power assist is nothing like that experienced when near stationery and parking. ![]()
Ill have to try this out. Have a similar problem. Belt squeeks for a few minutes on startup then exibites op's problem. New belt made no difference for me.
Thanks for sharing. |
