Key stuck in ignition??
Cant seem to remove my key from the ignition. Anyone had this problem? I have a 5mt if that means anything!! its stuck right before ACC.
Thanks Dave. thinking im going to disconnect the battery and see if that works. seems to just be locked in place. |
Re: Key stuck in ignition??
Its because it needs a signal to know the car is in park. Check over everything but that's what is causing the issue.
that crossed my mind. i havnt had the problem before. anyone with 5mt that can help me out how it was bypassed or however?
it might have come loose... but hopefully something can pipe in with something since I don't have experience with swaps yet...
The solenoid could be mechanically jammed or electrically energised and held in. The solenoid has no ground connection and is energised via a black/red and a blue/green wire.
Hell, mine does it all the time.. I just jiggle the keys and push till they come out.. Jiggling the shifter and moving it around a bunch seems to help too. Make sure it's in "Park" and whatnot.
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
iirc a completely dead/disconnected battery sticks the key too.
or atleast one time when I tried to start it with a flat battery it wouldn't give me the key back till I jumped the car to get some power. |
no "park" on a manual transmission
trevor, thanks im going to dig under the dash today. if it is energized and i disconnect it should come out im thinking??? i really dont care that its stuck.. i just dont have another key to lock it. meh.
Its funny, I just mentioned in a thread a moment ago that I never drove a manual car before. How does it stay still? The big brake handle? Mines broked..
under the ignition switch there's a plug you can remove and there's a lever you can toggle to release the key
When you leave the car in gear, it prevents it from moving.
